Advance cam or not?
#1191300
03/04/12 09:51 PM
03/04/12 09:51 PM
Posts: 4,588 St. John's Newfoundland
440newport
I have a Lunati voodoo 60302 in a stock compression 400, it's in a heavy 73 New Yorker with 2.76 gears. The motor has been in the car a couple of years now and runs pretty good for what it is but as you can imagine I could use more bottom end. When I degree'd it initially I was coming up with 109. I probably should have have fixed it then but left it at that. It has a cloyes 3 key chain and I was going to advance it 4 degrees, but some say too much advance is not good for a split pattern cam in a low comp motor? Advancing 4 degrees should put it at about 105. The cam has a 112LSA, compression is about 7.9. Will it make a noticeable difference or is it not recommended? cam specs
Re: Advance cam or not?
[Re: 440newport]
#1191301
03/04/12 09:58 PM
03/04/12 09:58 PM
RapidRobert
I would not be afraid to experiment. Do check V/P clearance
[Re: 440newport]
#1191303
03/04/12 11:07 PM
03/04/12 11:07 PM
Posts: 1,487 STL
cdstl
STL
After advancing a cam 4 degrees do you still set the timing at say 34 or 36 total? I have a 340.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#1191305
03/05/12 12:37 PM
03/05/12 12:37 PM
RapidRobert
you'd keep the total the same but alter the initial/curve(slots)/springs as the cam will change cyl psi & therefore the pinging point(s)
[Re: RapidRobert]
#1191307
03/05/12 02:24 PM
03/05/12 02:24 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Good question but if it's 7.9 compression , those piston are about .110 in the hole .
[Re: RobX4406]
#1191308
03/05/12 02:45 PM
03/05/12 02:45 PM
Posts: 3,916 usa
lewtot184
usa
If you installed it at 109 it's already 3* advanced from the 112 LSA. Now ,you want to advance it another 4 degerees to 7 total. Need to be careful you don't get the exh lobe way out there, it's going to be 119.
good reply. its probably the wrong cam for that combo.
[Re: JohnRR]
#1191309
03/05/12 08:48 PM
03/05/12 08:48 PM
440newport
They are 0.091 in the hole. With a 0.039 gasket and 90cc heads it comes out to be 7.9 or so using a calculator from what I remember.
[Re: 440newport]
#1191310
03/05/12 09:00 PM
03/05/12 09:00 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
it's already 3 degrees advance from the 112 LSA. I wouldn't go 7. if I had to go that far, I'd just get a new cam.
I would think maybe a 2 degree offset key in the cam might help, but I'm no cam expert.
**Photobucket sucks**
