5.7 hemi vs 6.1 crank #1187102
02/27/12 12:45 PM
02/27/12 12:45 PM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
spun a bearing in my 5.7 truck motor. Is the 6.1 crank the same crank? What are the differences?
Re: 5.7 hemi vs 6.1 crank [Re: xpsyclonex2002] #1187103
02/27/12 12:57 PM
02/27/12 12:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
5.7 cast
6.1 steel
both neutral balance
you can throw a 6.1 crank in a 5.7 without doing anything else, works great assuming the 5.7 is 2008 or older. I've done it several times now, works great.
Rich H.
Esse Quam Videri
Re: 5.7 hemi vs 6.1 crank [Re: ZIPPY] #1187104
02/27/12 01:24 PM
02/27/12 01:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Are they not balanced different for different bob weights? Do the 5.7 and 6.1 have the same bob weight?
Re: 5.7 hemi vs 6.1 crank [Re: ZIPPY] #1187105
02/27/12 04:16 PM
02/27/12 04:16 PM
Memphis, MO
X
X
Memphis, MO
5.7 cast
6.1 steel
What has to be done if the block is a 2005?
Re: 5.7 hemi vs 6.1 crank [Re: xpsyclonex2002] #1187106
02/27/12 08:47 PM
02/27/12 08:47 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
i think the crank tone wheel has a different trigger set up.
jm
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.7 hemi vs 6.1 crank [Re: wldtm] #1187107
02/28/12 09:59 AM
02/28/12 09:59 AM
NY usa
540challenger Offline
NY usa
jm
I know the 6.4l crank tone ring is different but i thought all 5.7 and 6.1l were the same.
Re: 5.7 hemi vs 6.1 crank [Re: 540challenger] #1187108
02/29/12 01:40 AM
02/29/12 01:40 AM
Memphis, MO
X
X
Memphis, MO
If I have spun a bearing, do I have to do a full blown rebuild or will turning the crank and new bearings be sufficient. The motor had 40K miles on it.
Re: 5.7 hemi vs 6.1 crank [Re: xpsyclonex2002] #1187109
03/01/12 11:12 PM
03/01/12 11:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Easy.
Drop in and go. Ive got several.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 5.7 hemi vs 6.1 crank [Re: xpsyclonex2002] #1187110
03/02/12 12:45 AM
03/02/12 12:45 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If it spun a bearing you need to take it apart for two reasons... first the rod is %99 chance it is toast, out of round or enlarged or both. Second is there is probably or should I say, there IS bearing material all over inside and it needs to be cleaned out.
