Radiator with in and out on bottom?? #1184112
02/22/12 05:37 PM
02/22/12 05:37 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Ever seen a set up like that? My friend just built an old Dodge P/U for a customer. The customer came in with a new aluminum radiator which had both in and out along the bottom tank. The engine is an early 392, blown hemi.
The thing is overheating and when you pull the cap it doesn't appear that water is cycling through the radiator.
We're not sure who built the radiator.
Should this work or is it doomed to fail??
Just checked his site, no photos of the engine or radiator:(
Re: Radiator with in and out on bottom?? [Re: PolyDart] #1184113
02/22/12 06:15 PM
02/22/12 06:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Won't work because the water isn't flowing through the cooling area of the radiator.
Re: Radiator with in and out on bottom?? [Re: PolyDart] #1184114
02/22/12 07:18 PM
02/22/12 07:18 PM
places
79powerwagon Offline
places
Is it a cross-flow rad that is mounted on it's side?
Re: Radiator with in and out on bottom?? [Re: 79powerwagon] #1184115
02/22/12 09:31 PM
02/22/12 09:31 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Sure doesn't appear that way. I will ask him if that's a possibility just in case!! Never know!!
Re: Radiator with in and out on bottom?? [Re: PolyDart] #1184116
02/23/12 12:47 AM
02/23/12 12:47 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
All you need is a divider in the center of the bottom tank. Flows up through one half of the core, crosses over in the top tank and then flows down in the other half of the core. I'm not saying that's what's happening but it could work that way.
Re: Radiator with in and out on bottom?? [Re: 6PakBee] #1184117
02/23/12 09:19 PM
02/23/12 09:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Good point but it makes me wonder how much of a restriction that path would create...And what would happen if, for whatever reason the water gets below a certain level...
