Re: Thermostat Recommendation
[Re: mcmopars]
#1183620
02/21/12 07:43 PM
02/21/12 07:43 PM
Posts: 654 Westfield, MA
rbrogle
super street
super street
Westfield, MA
I typically use the Mr. Gasket or Robertshaw premium thermostats. All of my A/C equipped C bodies seem to like 180 degree ones. Two of the cars have factory labels under the hood requiring their use. I use a 195 in the convertible 440, 26" rad., factory shroud and hood lip seal, clutch fan. Runs at 195 to 200 all day. Do not use a 160 degree thermostat!
Rob
'70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic
'68 300 2 Door HT vinyl/cloth bench
'68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED!
'68 New Yorker 4 Door HT, 440/Auto, loaded!
2004 Chrysler 300M Special daily driver
[Re: hergfest]
#1183621
02/21/12 08:19 PM
02/21/12 08:19 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Bought a new "Premium" Thermostat from Napa the other day installed it and it doesn't work. Gotta love it when a new part fails. So since I'm not going to buy another one of those, what do you guys recommend that would actually work? Car is a 1968 Roadrunner 383 4-speed 22" radiator, mostly freeway driven won't be near a track.
I like Milodon myself
[Re: MoparforLife]
#1183624
02/22/12 02:33 AM
02/22/12 02:33 AM
Posts: 3,438 Dandridge TN
Dabee
Dandridge TN
I would run with a 190/195 stat. Will run more efficiently with better lubrication.
[Re: Dabee]
#1183625
02/22/12 02:39 AM
02/22/12 02:39 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The temp rating on a thermostat is not the temp the motor is going to run at. It is the temp that the thermostat is wide open.
I am truckless..
[Re: 340SHORTY]
#1183626
02/22/12 08:20 AM
02/22/12 08:20 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
It is the minimum temp that the stat will maintain the coolant temp and make the engine reach operating temp quicker. It cannot control temps if the engine wants to run above the rating. If the cooling system is efficient and clean the temp should run pretty close to the stat rating.
[Re: torkrules]
#1183627
02/22/12 11:04 AM
02/22/12 11:04 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The Milodon thermostat as well as almost all of the so called high flow thermostats are the Robert Shaw origional factory installed thermostat from the 60/70's!
[Re: hergfest]
#1183628
02/22/12 11:59 AM
02/22/12 11:59 AM
Posts: 1,534 Florida
CHRGR69
Never had a problem with Stant, however, I always test new stats BEFORE installing. Also, drill the 1/16" bleeder hole while you have it out.
Grandma always said I had "hands of gold"!
