Thermostat Recommendation #1183618
02/21/12 06:42 PM
02/21/12 06:42 PM
NW
hergfest Offline OP
hergfest  Offline OP
NW
Bought a new "Premium" Thermostat from Napa the other day installed it and it doesn't work. Gotta love it when a new part fails. So since I'm not going to buy another one of those, what do you guys recommend that would actually work? Car is a 1968 Roadrunner 383 4-speed 22" radiator, mostly freeway driven won't be near a track.
Re: Thermostat Recommendation [Re: hergfest] #1183619
02/21/12 07:30 PM
02/21/12 07:30 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i also got junk from autozone,went to dealership,paid a little more but was well worth it.
Re: Thermostat Recommendation [Re: mcmopars] #1183620
02/21/12 07:43 PM
02/21/12 07:43 PM
Westfield, MA
rbrogle Offline
super street
rbrogle  Offline
super street
Westfield, MA
I typically use the Mr. Gasket or Robertshaw premium thermostats. All of my A/C equipped C bodies seem to like 180 degree ones. Two of the cars have factory labels under the hood requiring their use. I use a 195 in the convertible 440, 26" rad., factory shroud and hood lip seal, clutch fan. Runs at 195 to 200 all day.
Do not use a 160 degree thermostat!
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
Re: Thermostat Recommendation [Re: hergfest] #1183621
02/21/12 08:19 PM
02/21/12 08:19 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I like Milodon myself
Re: Thermostat Recommendation [Re: rbrogle] #1183622
02/21/12 08:22 PM
02/21/12 08:22 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Ok, stupid question. Why not a 165 stat vs a 180 stat? My car runs about 180-185, don't remember what stat was put in. Thinking 180, not sure.
Re: Thermostat Recommendation [Re: MI_Custumz] #1183623
02/21/12 09:26 PM
02/21/12 09:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would run with a 190/195 stat. Will run more efficiently with better lubrication.
Re: Thermostat Recommendation [Re: MoparforLife] #1183624
02/22/12 02:33 AM
02/22/12 02:33 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Re: Thermostat Recommendation [Re: Dabee] #1183625
02/22/12 02:39 AM
02/22/12 02:39 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The temp rating on a thermostat is not the temp the motor is going to run at. It is the temp that the thermostat is wide open.
I am truckless..
Re: Thermostat Recommendation [Re: 340SHORTY] #1183626
02/22/12 08:20 AM
02/22/12 08:20 AM
Upper Midwest
Upper Midwest
It is the minimum temp that the stat will maintain the coolant temp and make the engine reach operating temp quicker. It cannot control temps if the engine wants to run above the rating. If the cooling system is efficient and clean the temp should run pretty close to the stat rating.
Re: Thermostat Recommendation [Re: torkrules] #1183627
02/22/12 11:04 AM
02/22/12 11:04 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The Milodon thermostat as well as almost all of the so called high flow thermostats are the Robert Shaw origional factory installed thermostat from the 60/70's!
Re: Thermostat Recommendation [Re: hergfest] #1183628
02/22/12 11:59 AM
02/22/12 11:59 AM
CHRGR69 Offline
CHRGR69  Offline
Never had a problem with Stant, however, I always test new stats BEFORE installing. Also, drill the 1/16" bleeder hole while you have it out.
Grandma always said I had "hands of gold"!
Re: Thermostat Recommendation [Re: CHRGR69] #1183629
02/22/12 12:07 PM
02/22/12 12:07 PM
. 180 or higher & as said the rest of the cooling system up to snuff so it stays just above the stat rating
Re: Thermostat Recommendation [Re: RapidRobert] #1183630
03/04/12 07:12 PM
03/04/12 07:12 PM
MI_Custumz Offline
MI_Custumz  Offline
Found the paperwork for the stat put in. According to the part number and autozone's site it is a 160 degree stat. Part number says 3006
Re: Thermostat Recommendation [Re: MI_Custumz] #1183631
03/04/12 07:49 PM
03/04/12 07:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Please explain "doesn't work".
