Early B-body manual hump/floor opening #1177804
02/13/12 04:05 PM
02/13/12 04:05 PM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Does this opening look like factory job? How was it done at the factory? First an "automatic" floor pan was installed, then a hole was cut with an axe and covered with a manual hump? More pics of this area?
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Early B-body manual hump/floor opening [Re: Anselmi] #1177805
02/13/12 04:56 PM
02/13/12 04:56 PM
AndyF Offline
AndyF  Offline
I have a '65 Coronet 4spd car and mine looked like that. The opening was very ragged like it was cut with a whiz wheel or something. They must not have tooled up a floor shifter floor that year?
Re: Early B-body manual hump/floor opening [Re: Anselmi] #1177806
02/13/12 05:12 PM
02/13/12 05:12 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
I am doing a 69 A-12 Roadrunner that looks the same way. Were all the 4 speed cars like this?
Re: Early B-body manual hump/floor opening [Re: Mopargnome] #1177807
02/13/12 05:21 PM
02/13/12 05:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: Early B-body manual hump/floor opening [Re: 6bblgt] #1177808
02/13/12 06:48 PM
02/13/12 06:48 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Dan- actually, that is very typical of the '62-5 B-bodies. From the looks of my '63 Savoy, my guess is that is was torch cut. Here is a pic of an original MW Sport Fury that Rocket restored. Notice the cut is nearly the same as the one in question.
Re: Early B-body manual hump/floor opening [Re: 70440+6bbl] #1177809
02/13/12 06:51 PM
02/13/12 06:51 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Pic of my Savoy.
Re: Early B-body manual hump/floor opening [Re: 70440+6bbl] #1177810
02/13/12 07:30 PM
02/13/12 07:30 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
My mistake!
I didn't think the removal of the passenger side of the "hump" was that complete & looked like 2-pieces added.
Here's a pic of another '63 3-spd car at "ROCKET", thanks Tom!
Re: Early B-body manual hump/floor opening [Re: 6bblgt] #1177811
02/13/12 07:32 PM
02/13/12 07:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& a '64
Re: Early B-body manual hump/floor opening [Re: 70440+6bbl] #1177812
02/13/12 11:37 PM
02/13/12 11:37 PM
AndyF Offline
AndyF  Offline
Yes, it might have been a torch. My floor had some very jagged edges. I ground them off in the interest of safety. At the time I wasn't interested in a correct restoration. Still not sure I'd leave a car looking that way even if I was performing a restoration. My car was dangerous to work on with the sharp jagged edges hanging down there.
Re: Early B-body manual hump/floor opening [Re: AndyF] #1177813
02/14/12 01:13 PM
02/14/12 01:13 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
My 65 is an original 4-sp - floor cut was very rough - it was obviously done with a torch. similar to 1st photo from memory
Re: Early B-body manual hump/floor opening [Re: SSAAHemiFan] #1177814
02/16/12 04:04 AM
02/16/12 04:04 AM
Helsinki, Finland
Anselmi Offline OP
Anselmi  Offline OP
Helsinki, Finland
Thanks, guys! Here is a pic from slightly different angle showing edges that clearly look like they were torched. The hole for adjusting transmission linkage on the side of the hump will be welded shut, and shifter opening brought back to factory specs. Then we can move on towards the rear of the car
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
