Worn Dana 60 housing. #1177349
02/12/12 08:03 PM
02/12/12 08:03 PM
PA
moparacer Offline OP
PA
I have a Dana 60 housing in my racecar that has the dreaded worn housing where the driver side carrier bearing sets.
Is this something that can be repaired fairly easy or is it better off just to replace the whole housing? This would be major for me since this is a narrowed 4 link housing with brackets on it.....
I see you can get an axle bore facing tool to correct this? Anyone ever do this type of repair?
Where can you buy a tool?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Worn Dana 60 housing. [Re: moparacer] #1177350
02/12/12 08:39 PM
02/12/12 08:39 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Mine was doing the same thing and a few guys here told me to take a .002 off of the caps so they clamp the bearing cup better I never did it and just bolted on a support cover
Gus
64 Plymouth Savoy
Dana 60
Re: Worn Dana 60 housing. [Re: moparacer] #1177351
02/12/12 08:40 PM
02/12/12 08:40 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
So you are saying the bearing race will spin when you tighten down the cap bolts ? It does not look like it has spun in there ?
Re: Worn Dana 60 housing. [Re: VernMotor] #1177352
02/12/12 08:59 PM
02/12/12 08:59 PM
Rittman Ohio
Rittman Ohio
Unless I misunderstood the explanation I was told the bearing caps are bouncing causing the shiny spots like "cap walk" on main bearing surfaces.Now I cant see why trimming the caps would stop this from happening but I would think a new set of Strange caps would be the correct repair.
Gus
64 Plymouth Savoy
Dana 60
Re: Worn Dana 60 housing. [Re: fourgearsavoy] #1177353
02/12/12 09:04 PM
02/12/12 09:04 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
OK I can see a little cap walk there..I not sure I would worry about it. he got studs in there. and not sure there is much more you can do about it. excerpt like you say buy some big buck caps..and that may not stop it..
Re: Worn Dana 60 housing. [Re: fourgearsavoy] #1177354
02/12/12 09:09 PM
02/12/12 09:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i beleive he stated the bearing race is loose not the cap. he could have a little taken off the caps as mentioned & that would increase the clamping force. i have done this at work. solved the problem. seeya.
Re: Worn Dana 60 housing. [Re: rickraw] #1177355
02/12/12 09:21 PM
02/12/12 09:21 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
Dana makes a tool that centers a shaft with a cutter through the caps it cuts the sides of the housing back square again. You need to shim the bearings out more once its cut. You can also do it with a sanding disk in a air angle clean up tool. I think A&D in jackson nj has the right tool.
Re: Worn Dana 60 housing. [Re: moparacer] #1177356
02/12/12 09:28 PM
02/12/12 09:28 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a common problem.
I charge $50 to machine the face of the carrier bores, but shipping would be prohibitive.
The housing tool is fairly common now, so I wouldn't be surprised if a local shop has one.
In addition, kiss the carrier caps to create a 0.001" interference fit with the bearing races.
Re: Worn Dana 60 housing. [Re: NoFrills] #1177357
02/12/12 09:30 PM
02/12/12 09:30 PM
PA
PA
If you look you can see the groove where the outside of the race has worn the housing.
Here is a pic of the other side. This is how the driver side is supposed to look.
I don't know if the race spins, or the deflection from the bearing load beats up the case.
I suspect, this all starts when the carrier bearing preload is insufficient.
Re: Worn Dana 60 housing. [Re: DoctorDiff] #1177358
02/12/12 09:33 PM
02/12/12 09:33 PM
PA
PA
Man Dr. I wish you were closer to me I would give you this mess so you could fix it right. You say the tools are fairly common? Where did you get your tool? You don't happen to know where I can get one do you?
Re: Worn Dana 60 housing. [Re: moparacer] #1177359
02/12/12 09:37 PM
02/12/12 09:37 PM
PA
PA
Tool to sell? or they do the repair?
Thanks!
Re: Worn Dana 60 housing. [Re: moparacer] #1177360
02/12/12 09:48 PM
02/12/12 09:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A machine shop in the Lewiston/Clarkston (ID/WA) area makes the tool, not Dana/Spicer.
I bought mine directly from the source years ago. I think Randy's Ring and Pinion distributes it now.
The tool is not exactly cheap, though.
Re: Worn Dana 60 housing. [Re: DoctorDiff] #1177361
02/12/12 10:09 PM
02/12/12 10:09 PM
PA
PA
Thats what I was afraid of.
If it gets too expensive I might be better off to get a new Stange housing and 4 link brackets and build a new one.
Re: Worn Dana 60 housing. [Re: moparacer] #1177362
02/12/12 10:14 PM
02/12/12 10:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I would check around first. A well equipped 4 x 4 or drivetrain shop should have the tool.
Re: Worn Dana 60 housing. [Re: DoctorDiff] #1177363
02/12/12 10:32 PM
02/12/12 10:32 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
I can do it if Your interested
I'm right in Downtown Greensburg
www.GreensburgMachine.Com
Re: Worn Dana 60 housing. [Re: Mpetros] #1177364
02/12/12 10:44 PM
02/12/12 10:44 PM
PA
PA
LOL I was just searching for driveline services in my area and was on your sight when you posted here.
You must have been reading my mind.
I will give you a call tomorrow.
