Can't stop thermostat housing leak #1177014
02/12/12 12:16 PM
02/12/12 12:16 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Is it ok to double up a gasket on the thermostat housing? I have a small drip that can't be stopped and I noticed that the thermostat housing rocks back and forth on the intake and I tried to balance it out some but still not great. If it is ok to double up do I need to use RTV or ultra copper also? Thx
Re: Can't stop thermostat housing leak [Re: tee-john] #1177015
02/12/12 12:19 PM
02/12/12 12:19 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
I use the RVT on the housing side. You may want to put a straight edge across the housing to check for flatness.
1979 Chrysler 300 1968 Barracuda project
Re: Can't stop thermostat housing leak [Re: LS-300] #1177016
02/12/12 12:31 PM
02/12/12 12:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I just use a good gasket and brown Permatex.Mine is chrome and never leaks.Rocky
Chrysler Firepower
Re: Can't stop thermostat housing leak [Re: tee-john] #1177017
02/12/12 12:45 PM
02/12/12 12:45 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
if it rocks that should tell you something.is it the chrome one by chance? i had to work mine over to get it true. then used the red gasket sealer
Re: Can't stop thermostat housing leak [Re: tee-john] #1177018
02/12/12 01:10 PM
02/12/12 01:10 PM
it's severely warped. Drawfile it (& the flange it sits on) & see if you can get it flat
Re: Can't stop thermostat housing leak [Re: tee-john] #1177019
02/12/12 03:30 PM
02/12/12 03:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Contact Moparts member here Gregg Travis AKA Roadhazard for the gasket you need.He makes a few different types for whatever housing you are using.
Got his gaskets on my w.pump housing with a motor plate with zero sealer and ZERO leaks.I also am using a chrome water neck and one of his gaskets dry with zero leaks there as well
Best darn gaskets money can buy
Gus
64 Plymouth Savoy
Dana 60
Re: Can't stop thermostat housing leak [Re: fourgearsavoy] #1177020
02/12/12 03:39 PM
02/12/12 03:39 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
take housing off,buff clean and dry,mask off chrome area,spray with light coat of primer or paint,once dry secure in vise, run flat file across the flange and any high spots on it will have the primer takin off,continue this process until its flat
Re: Can't stop thermostat housing leak [Re: tee-john] #1177021
02/12/12 03:52 PM
02/12/12 03:52 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If it is 1 of those chrome Mopar Performance Chinese specials...
Toss it in the dumpster, you can sand it, grind it, put multiple gaskets and layers of RTV it will still leak..
The problems is the low quality recycled material used....
Get yourself an OE cast iron clone from Napa or the nice billet one from Mancini..
Just my $0.02...
Re: Can't stop thermostat housing leak [Re: Sinitro] #1177022
02/12/12 04:19 PM
02/12/12 04:19 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Just my $0.02...
Had on of those same things replaced the neck and gasket with a thin layer of mopar gray sealant and problem solved.
Re: Can't stop thermostat housing leak [Re: Todd] #1177023
02/12/12 05:11 PM
02/12/12 05:11 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I use the brown permatex to seal it....Used to apply the Blue RTV ..
As for the rocking...take it off and file it down. It can't be that hard. Go in single motion in one direction. I had to file my one cast iron HP manifold and it took me 10 hours over 2 days to do so. Don't double up the gaskets because the gaskets will probably end up blowing out while you are on the road and then you will wish you had done it the right way. If you gotta get the car somewhere fast, then yeah...double up...but don't leave it accident prone.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Can't stop thermostat housing leak [Re: RapidRobert] #1177024
02/12/12 05:33 PM
02/12/12 05:33 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
x 2 ... ORE just put it on a belt-sander and that should straighten it out
Re: Can't stop thermostat housing leak [Re: Sinitro] #1177025
02/12/12 05:48 PM
02/12/12 05:48 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quoteIf it is 1 of those chrome Mopar Performance Chinese specials...
x10!!!!
I had one, filed the neck ifself, filed the housing, used right stuff, etc...it never stopped leaking. Total POS.....
I took a chance and tried the billet piece from Source. Never a drop.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
