Re: Can't stop thermostat housing leak
[Re: tee-john]
#1177015
02/12/12 12:19 PM
02/12/12 12:19 PM
Posts: 304 Ohio
LS-300
Ohio
I use the RVT on the housing side. You may want to put a straight edge across the housing to check for flatness.
1979 Chrysler 300
1968 Barracuda project
[Re: LS-300]
#1177016
02/12/12 12:31 PM
02/12/12 12:31 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I just use a good gasket and brown Permatex.Mine is chrome and never leaks.Rocky
Chrysler Firepower
[Re: tee-john]
#1177017
02/12/12 12:45 PM
02/12/12 12:45 PM
Posts: 1,012 indiana
mcmopars
indiana
Is it ok to double up a gasket on the thermostat housing? I have a small drip that can't be stopped and I noticed that the thermostat housing rocks back and forth on the intake and I tried to balance it out some but still not great. If it is ok to double up do I need to use RTV or ultra copper also? Thx
if it rocks that should tell you something.is it the chrome one by chance? i had to work mine over to get it true. then used the red gasket sealer
[Re: tee-john]
#1177018
02/12/12 01:10 PM
02/12/12 01:10 PM
RapidRobert
it's severely warped. Drawfile it (& the flange it sits on) & see if you can get it flat
[Re: tee-john]
#1177019
02/12/12 03:30 PM
02/12/12 03:30 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Contact Moparts member here Gregg Travis AKA Roadhazard for the gasket you need.He makes a few different types for whatever housing you are using. Got his gaskets on my w.pump housing with a motor plate with zero sealer and ZERO leaks.I also am using a chrome water neck and one of his gaskets dry with zero leaks there as well Best darn gaskets money can buy Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: tee-john]
#1177021
02/12/12 03:52 PM
02/12/12 03:52 PM
Posts: 5,447 So Cal
Sinitro
So Cal
If it is 1 of those chrome Mopar Performance Chinese specials... Toss it in the dumpster, you can sand it, grind it, put multiple gaskets and layers of RTV it will still leak.. The problems is the low quality recycled material used....
Get yourself an OE cast iron clone from Napa or the nice billet one from Mancini..
Just my $0.02...
[Re: Sinitro]
#1177022
02/12/12 04:19 PM
02/12/12 04:19 PM
Posts: 1,377 Ohio
Todd
Ohio
Just my $0.02...
Had on of those same things replaced the neck and gasket with a thin layer of mopar gray sealant and problem solved.
[Re: Todd]
#1177023
02/12/12 05:11 PM
02/12/12 05:11 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I use the brown permatex to seal it....Used to apply the Blue RTV ..
As for the rocking...take it off and file it down. It can't be that hard. Go in single motion in one direction. I had to file my one cast iron HP manifold and it took me 10 hours over 2 days to do so. Don't double up the gaskets because the gaskets will probably end up blowing out while you are on the road and then you will wish you had done it the right way. If you gotta get the car somewhere fast, then yeah...double up...but don't leave it accident prone.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RapidRobert]
#1177024
02/12/12 05:33 PM
02/12/12 05:33 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
x 2 ... ORE just put it on a belt-sander and that should straighten it out
[Re: Sinitro]
#1177025
02/12/12 05:48 PM
02/12/12 05:48 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[quoteIf it is 1 of those chrome Mopar Performance Chinese specials... Toss it in the dumpster, you can sand it, grind it, put multiple gaskets and layers of RTV it will still leak..
x10!!!!
I had one, filed the neck ifself, filed the housing, used right stuff, etc...it never stopped leaking. Total POS.....
I took a chance and tried the billet piece from Source. Never a drop.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
