ENGINE DIAPER OR BELLY PAN ? #1173715
02/07/12 01:15 AM
02/07/12 01:15 AM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
With the new NHRA rule changes. Im wondering what some of you are going to run a engine diaper or a custom belly pan. I have a caps tubular k and would like a belly pan but with my headers and the rules I just dont see it possible. Anyone have some pictures of belly pans or diapers installed on a non-tubbed chassis car?
Re: ENGINE DIAPER OR BELLY PAN ? [Re: FIREGUY12] #1173716
02/07/12 10:19 AM
02/07/12 10:19 AM
Out West
408strokerdart Offline
Out West
I was contemplating the same thing. I have decided to go with a diaper. The purpose is for fluid containment and I just can't see how a belly pan can keep the oil contained at speed. I know they functionally help in other ways and don't trap heat, but I just can't believe they would hold the oil from blowing out of a big hole in the side of a pan.
Re: ENGINE DIAPER OR BELLY PAN ? [Re: FIREGUY12] #1173717
02/07/12 10:57 AM
02/07/12 10:57 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Diaper....
Re: ENGINE DIAPER OR BELLY PAN ? [Re: FIREGUY12] #1173718
02/07/12 11:12 AM
02/07/12 11:12 AM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
DIAPER!
I agree....can't see how a belly pan can contain the explosion of fluids when the block shatters.
Having been thru a catastrophic engine failure and the car going sideways at the 1/8th I will never run a car again without a diaper.
Contact Dennis @ DRE.
Great Guy to work with and the custom end product is very nicely crafted.
Brett Miller 447 W9
Re: ENGINE DIAPER OR BELLY PAN ? [Re: smokinwoody] #1173719
02/07/12 11:12 AM
02/07/12 11:12 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
x3
2011 Drag Pak Challenger
Re: ENGINE DIAPER OR BELLY PAN ? [Re: rickseeman] #1173720
02/07/12 11:50 AM
02/07/12 11:50 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
I think a diaper would be better also. But my concern is my headers hug the engine block so close Im concerned the diaper will burn. Anyone have pictures of a diaper on their car. On a stock type or tublar K frame front end?
Re: ENGINE DIAPER OR BELLY PAN ? [Re: FIREGUY12] #1173721
02/07/12 12:16 PM
02/07/12 12:16 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Diaper can be made with heat cloth overlay in problem areas.
I can take and send you a picture of mine with the heat cloth overlay later this evening if you want.
Not installed on engine yet...still in box.
My headers will be 1/8" away from diaper.
DRE said it would not be a problem.
Let me know.
Brett Miller 447 W9
Re: ENGINE DIAPER OR BELLY PAN ? [Re: mcduff] #1173722
02/07/12 10:00 PM
02/07/12 10:00 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I have the DRE with a heat shield and they sit right on the header. I little singed, but still funtional. Just be sure the straps don't touch the header since they will burn through.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: ENGINE DIAPER OR BELLY PAN ? [Re: Dads426] #1173723
02/07/12 10:44 PM
02/07/12 10:44 PM
oregon
greendart408 Offline
oregon
I have been wondering what would be best also. So this rule will be in effect this yr for 9.99 and faster forsure?? I keep getting conflicting answers.
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 408strokerdart] #1173724
02/08/12 12:11 AM
02/08/12 12:11 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
You line the pan with a PIG mat. Go to Newpig.com and check them out.
Re: ENGINE DIAPER OR BELLY PAN ? [Re: Dart1031] #1173725
02/08/12 12:59 AM
02/08/12 12:59 AM
Out West
Out West
I was specifically talking about the the distance that the oil might have to fall for a bely pan to catch it. There is alot of turbulent air under a car at speed.
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 408strokerdart] #1173726
02/08/12 05:14 AM
02/08/12 05:14 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I bought Russlers pure junk 3.00 worth of a nylon type material that melted . It used straps like a helmet plus cheap plastic snap catches like on a kid's knap sack. there are no NHRA rules or specs for those not required to be SFI approved. You can tie an old hunk of a tarp to the car with duct tape and it would not only be better but still legal
home of the
Sox and Martin Hemi Duster
Re: ENGINE DIAPER OR BELLY PAN ? [Re: HEMIFRED] #1173727
02/08/12 12:31 PM
02/08/12 12:31 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I talked to Dennis at DRE yesterday about one for the Hemi. Said he puts double layer of heat protection close to the header area. Recomended not using it on the street though do to the heat of the headers. Said his take about 5 minutes to remove. Very nice/helpful guy.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 67HEMI] #1173728
02/08/12 07:27 PM
02/08/12 07:27 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Yeah he's a nice guy wait til you get his price. $500 plus . BS
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 65dragnet] #1173729
02/08/12 08:52 PM
02/08/12 08:52 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Here is my belly pan its worked well for me.It has contained a coolant spill of several quarts I didnt know how much till I refilled the motor. There was no coolant standing in the pan as I made several more passes that day. It has a pig mat in the bottom held in place w/ aluminium screen. It doesnt hold in heat,I can remove or install it in about 10 minutes.It passes tech.I have no idea if it would contain everything in the evevt of a motor explosion. I do have at least 2 friends who use a simular pan on thier top sportsman cars that run over 200 mph. It has worked well for them also.
Re: ENGINE DIAPER OR BELLY PAN ? [Re: DavidDean] #1173730
02/08/12 08:54 PM
02/08/12 08:54 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
another pic
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 65dragnet] #1173731
02/08/12 09:46 PM
02/08/12 09:46 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Small price to pay to keep your $50,000.00+ race car off the wall or from taking out the guy next to you........
"Cheap ain't good and good ain't cheap"
Brett Miller 447 W9
Re: ENGINE DIAPER OR BELLY PAN ? [Re: 65dragnet] #1173732
02/09/12 03:40 PM
02/09/12 03:40 PM
67HEMI Offline
67HEMI  Offline
He told me 300 for the Hemi I thought that was very reasonable.
