8 3/4 questions #1172445
02/05/12 12:28 PM
02/05/12 12:28 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Gonna be putting a 8 3/4 in my 67 barracuda and don't know much about them. I have a 489 case but Ive been told I can put any carrier in any case so my question is which is best for mostly street 500 hp big block, the one with clutches or the cone type. Ive heard conflicting advice about both so I would appreciate any help. Thanks, Clay
Re: 8 3/4 questions [Re: Clayton] #1172446
02/05/12 02:28 PM
02/05/12 02:28 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Use the clutch type. I have the cone type and it only hooks one wheel sometimes, sometimes both. It's a crapshoot.
Scott
1969 Super Bee, 383/4 speed
Re: 8 3/4 questions [Re: StukaJU87] #1172447
02/05/12 03:00 PM
02/05/12 03:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it's spent , eventually the spiders are going to gall and sieze to the shaft , the shaft will spin once it snaps the dowel that holds it then it will ruin the case .
Benn there .
OP , buy ANYTHING but any type of cone type .
Re: 8 3/4 questions [Re: JohnRR] #1172448
02/05/12 03:13 PM
02/05/12 03:13 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
So I can just get any clutch type carrier from 741,742,489 case, add the gears I want and I'll be fine? Sorry if these seem like dumb questions but at this point I've been told so many things that I'm not sure what is right and I figured this would be the best place to ask;)
Re: 8 3/4 questions [Re: Clayton] #1172449
02/05/12 03:14 PM
02/05/12 03:14 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The title read 8 3/4 questions.
I only read one question. Feel free to add in the other 7 3/4 questions. We are always willing to help.
Re: 8 3/4 questions [Re: Kern Dog] #1172450
02/05/12 03:16 PM
02/05/12 03:16 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
does a 3/4 race cam work well in a 440?
Re: 8 3/4 questions [Re: Pacnorthcuda] #1172451
02/05/12 03:17 PM
02/05/12 03:17 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The 3/4 race cam is for HALF assed Chevy guys!
Re: 8 3/4 questions [Re: Pacnorthcuda] #1172452
02/05/12 03:28 PM
02/05/12 03:28 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
I might have to stop at 8 5/8 questions before I learn just enough to be dangerous...:)
Re: 8 3/4 questions [Re: Clayton] #1172453
02/05/12 03:29 PM
02/05/12 03:29 PM
What size socket is required to adjust torsion bar ride height?
Re: 8 3/4 questions [Re: JohnRR] #1172454
02/05/12 03:59 PM
02/05/12 03:59 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Great. I was under the impression that it will just act like an open rear when it's shot completely. Now I have to worry about when it will be grenading?
Scott
Re: 8 3/4 questions [Re: StukaJU87] #1172455
02/05/12 04:41 PM
02/05/12 04:41 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I must be one of the lucky ones. Purchased a 3.73 cone type pig from Randy's 10 years ago. Still works perfect.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 8 3/4 questions [Re: Junky] #1172456
02/05/12 05:26 PM
02/05/12 05:26 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Yea popular opinion seems to be the clutch type especially since its rebuildable. Now have to pull the center and see whats in it, since its been back braced and has aftermarket axels I have the sneeking suspicion thats its spooled......
Re: 8 3/4 questions [Re: Junky] #1172457
02/05/12 05:31 PM
02/05/12 05:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is always one in every crowd .....
Re: 8 3/4 questions [Re: StukaJU87] #1172458
02/05/12 05:31 PM
02/05/12 05:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would be a big YES ...
Re: 8 3/4 questions [Re: JohnRR] #1172459
02/05/12 05:46 PM
02/05/12 05:46 PM
Minn
SportF Offline
SportF  Offline
Minn
I wasn't going to reply to this as this topic comes up all the time. Why will the spyder gears gall. There isn't much load on them when the unit is wore and there is no load going straight ahead. On the cone vs clutch, those clutch types (used) are pretty rare. The cone types can be rebuilt as well. If only one wheel grabs the unit is wore. I rebuilt a wore out cone unit 15 years ago, and crudely at that. In a '62 Plymouth running low 12's with well over 400 passes and 10k in hard street miles it still works. This is with tapered axles and a ball and trunnion joint at the tranny, and that isn't suppose to work either. I took a cone type gear set out of a junkyard truck with 200,000+ miles on it and the cone stuff was still good. Give me the cone stuff every time. This isn't stuff I think, its stuff I know. Good luck.
Re: 8 3/4 questions [Re: SportF] #1172460
02/05/12 05:55 PM
02/05/12 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The cone-type spider gears are more likely to gall because there's only two of them, the clutch-type has four.
Since it's unlikely that any two tires are the exact same diameter, the differential gears will be under load even when going straight ahead.
Re: 8 3/4 questions [Re: SportF] #1172461
02/05/12 06:02 PM
02/05/12 06:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You run into problems when the cones wear and the unit turns into an open differential.
If you do many 1 wheel burn-outs with a worn cone sure-grip, the spider gears friction weld themselves to the differental cross shaft. This causes the cross shaft to spin, which eventually wallows out the pin bore in the carrier.
Re: 8 3/4 questions [Re: John_Kunkel] #1172462
02/05/12 06:17 PM
02/05/12 06:17 PM
Minn
SportF Offline
SportF  Offline
Minn
Doesn't that also means open rears must be subject to the same galling effect, if not more, and you really don't hear much of that, unless you run low on oil.
Re: 8 3/4 questions [Re: SportF] #1172463
02/05/12 06:43 PM
02/05/12 06:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Open differentials suffer the same fate. I see it all the time.
If you perform extended burn outs with an open differential, you will friction weld the spider gears.
Because spider gears do not contain bearings, they are designed to spin SLOWLY only when the vehicle goes around corners, NOT thousands of RPMs during a 1 wheel burn-out.
Of course, this can also happen with an over-zealous driver stuck in mud/snow/ice.
Re: 8 3/4 questions [Re: DoctorDiff] #1172464
02/05/12 06:50 PM
02/05/12 06:50 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
So, I guess I will soon be needing a new Eaton TrueTrac somewhere down the line.
Seriously though....if I drive the worn out cone type without doing extensive burnouts, will it live or self destruct?
Scott
