Re: 8 3/4 questions
[Re: StukaJU87]
#1172447
02/05/12 03:00 PM
02/05/12 03:00 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Use the clutch type. I have the cone type and it only hooks one wheel sometimes, sometimes both. It's a crapshoot.
it's spent , eventually the spiders are going to gall and sieze to the shaft , the shaft will spin once it snaps the dowel that holds it then it will ruin the case .
Benn there .
OP , buy ANYTHING but any type of cone type .
Re: 8 3/4 questions
[Re: Kern Dog]
#1172450
02/05/12 03:16 PM
02/05/12 03:16 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
The title read 8 3/4 questions. I only read one question. Feel free to add in the other 7 3/4 questions. We are always willing to help.
does a 3/4 race cam work well in a 440?
Re: 8 3/4 questions
[Re: Junky]
#1172457
02/05/12 05:31 PM
02/05/12 05:31 PM
JohnRR
U.S.S.A.
I must be one of the lucky ones. Purchased a 3.73 cone type pig from Randy's 10 years ago. Still works perfect.
There is always one in every crowd .....
Re: 8 3/4 questions
[Re: StukaJU87]
#1172458
02/05/12 05:31 PM
02/05/12 05:31 PM
JohnRR
U.S.S.A.
Great. I was under the impression that it will just act like an open rear when it's shot completely. Now I have to worry about when it will be grenading?
That would be a big YES ...
Re: 8 3/4 questions
[Re: SportF]
#1172460
02/05/12 05:55 PM
02/05/12 05:55 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The cone-type spider gears are more likely to gall because there's only two of them, the clutch-type has four.
Since it's unlikely that any two tires are the exact same diameter, the differential gears will be under load even when going straight ahead.
Re: 8 3/4 questions
[Re: DoctorDiff]
#1172464
02/05/12 06:50 PM
02/05/12 06:50 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
So, I guess I will soon be needing a new Eaton TrueTrac somewhere down the line. Seriously though....if I drive the worn out cone type without doing extensive burnouts, will it live or self destruct?
Scott
1969 Super Bee, 383/4 speed
