DANA 60 #1171003
02/03/12 08:34 AM
02/03/12 08:34 AM
SD800 Offline OP
SD800  Offline OP
Picked up a Dana 60 last weekend, it is out of a mopar car and would like to know what it may have come out of, the width is 56 3/4 inches wide so I'm sure it was in an e-body, the ends are welded on about 3 inches from the flange so it looks like it was made wider.
any way to tell from the numbers cast into the center section when it was made?
Did they stamp Vin numbers on them?
Thanks guys
You'll have plenty of time to sleep when your dead, let's go
Re: DANA 60 [Re: SD800] #1171004
02/03/12 09:23 AM
02/03/12 09:23 AM
BDW Offline
BDW  Offline
No way to match to VIN, only type of car.
Re: DANA 60 [Re: BDW] #1171005
02/03/12 01:17 PM
02/03/12 01:17 PM
SD800 Offline OP
SD800  Offline OP
Thanks for the info.
Re: DANA 60 [Re: SD800] #1171006
02/03/12 11:00 PM
02/03/12 11:00 PM
SD800 Offline OP
SD800  Offline OP
Date code is march 20th of 1969 can't find the BOM
