Re: does your street car run between 10.50's and 11.30's?
[Re: shoebox]
#1170775
02/02/12 06:52 PM
02/02/12 06:52 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What spec is your car, motor ,converter, gear,weight etc.? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: shoebox]
#1170776
02/02/12 06:54 PM
02/02/12 06:54 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
you know mine does ![](/ubbthreads/images/graemlins/biggrin.gif) if it would stop raining i could see if it will go faster ![](/ubbthreads/images/graemlins/2245452-furysmiley.gif) Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BigBlockMopar]
#1170779
02/02/12 07:07 PM
02/02/12 07:07 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
My '69 Roadrunner runs right at the 11.00 to 10.95 fully dressed through the mufflers @ 3750 lbs without me in it so it is around 4000 lbs setting on the starting line. I have a 457CID motor with B1-BS heads and a M1 tunnel ram. Richmond 5 speed with Caltracs. If you lighten the car you will go quicker and faster without having to have to much motor. A Duster/Demon type car with a good 408 should be able to run those numbers. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Biginchmopar]
#1170781
02/02/12 07:49 PM
02/02/12 07:49 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Should be in the 11.teen range, driven to the track raced, then home. .030 11.2:1 stock stroke 440, Ross pistons, H-beam rods, ported Stage VI heads, Comp Cams 588 solid roller cam, 1 3/4 headers (2" for spring), Stock 6-pack w/ water/meth injection, 3800 Turbo Action stall, RMVB, 3.91's. Pump gas full interior.
[Re: BigBlockMopar]
#1170782
02/02/12 07:51 PM
02/02/12 07:51 PM
Posts: 2,449 nc
earthmover
nc
My daily could run low 11's on a good day if needed.... but there's still lots of track left in front of it then... Like about half of it orso ![](/ubbthreads/images/graemlins/biggrin.gif)
Pic? You asked for it...!
![](http://img.photobucket.com/albums/v628/BigBlockMopar/1973DodgeDart/20110904-73Dart-SNC-crop.jpg)
you have any pics of the car where you can see the top of the car..like the black part..my dart is about to be painted some day and that may work ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: earthmover]
#1170783
02/02/12 08:20 PM
02/02/12 08:20 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63 Sport Fury has run 10.70's so far with only 7 passes on the eng. I drive it to the track and run on 92 pump and race thru the full exh system. Here is the combo : 440 block .030 over with 440Source 4.15 stroker kit for 493 cubes. Dished pistons to get 10.6 comp with the Indy EZ heads I use. Custom grind solid flat tappet from Dwayne Porter of 264 & 270 at .050 and .630 lift with my Hughes 1.6 rockers. Indy dual plane intake with an 850 DP. Mallory dist and MP orange ECU box. 2" TTI headers and 3" X-pipe exh to rear bumper. 727 with reverse manual V/B and 9.5 Dynamic converter that flashes about 4200 but really drives great on the street. 8-3/4 with 4.30's and I use a 30 x 9 tire. Car weighs just over 3700 with me in it and has run best of 10.76 @ 124.49 so far. I think it has easy 10.50's in it when I get time to work with the combo some. Ron ![](http://i338.photobucket.com/albums/n429/383-manallmopar/100_1534.jpg)
[Re: sunroofgtx]
#1170792
02/02/12 10:44 PM
02/02/12 10:44 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I'm hoping my old truck is a might bit faster than 10.50 this summer. I'm waiting on Jeff@MCH to tweak my heads a bit more. Dave
