Do I need zinc additive?
#1169931
02/01/12 11:52 AM
02/01/12 11:52 AM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I should have thought of this sooner; should I be using a zinc additive in my stock 1980 E58 Aspen?
Thanks.
Facts are stubborn things.
Re: Do I need zinc additive?
[Re: chargincharles]
#1169935
02/01/12 03:48 PM
02/01/12 03:48 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
anything I own NON roller gets it, Hell even my Full roller 408 gets it. Its good oil, and parts like it.
Im a Brad Penn guy, so everything I own except my 07 Charger, and my 79 John Deere 4230 gets brad penn, 2 harleys, my Demon, my Ramcharger, my 78 power wagon, everything.....
there is Brad penn 10w30
Kasey
[Re: larrymopar360]
#1169936
02/02/12 02:13 AM
02/02/12 02:13 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I know there are varying views on this, but I am a little concerned about synthetic in it due to very high mileage. I will at least use an additive now though. Thanks.
[Re: larrymopar360]
#1169937
02/02/12 08:47 AM
02/02/12 08:47 AM
Posts: 4,723 Florida
BDW
Hard to beat Lucas for the money. One bottle of the break-in additive will do 3-4 oil changes. Local Advanced Autos carry it too, so no shipping.
[Re: BDW]
#1169938
02/02/12 10:11 AM
02/02/12 10:11 AM
Posts: 15,487 Florida
scratchnfotraction
a small bottle of STP will do fine the red bottle for 4 cyls has more than the blue on the ZDDP lucas/hughes/comp/GM break in additives will work. I just use a blue bottle of STP in my 440 with a 10/30 napa house brand oil change. I use a napa gold filter on all of mine my roller cam in the SB gets a bottle of STP and the 10/30 oil also,cant hurt to run I geuss..but I did go roller for this reason,and its now in the 2nd engine with different roller lifters this time. no need for to much snake oil additives,i think some of the gas tretment might help carbon up the valves like mine were I am cheap and use the STP from walmart for 2.00$ a bottle
#1169939
02/02/12 10:29 AM
02/02/12 10:29 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
If it were me- Anything made before 1990 gets Zinc additive- or I run Delvac or Rotella or comparable diesel oil. Not the synthetic though. The standard diesel oils have a high zinc content. Run a search of the forum, you will find a number of posts about this topic.
CC.
Weren't the diesel oils changed about 4 years ago though ?
I would say he wants an ADDITIVE , how is break in lube formulated compared to an additive.
I think the best oil is one that has the zinc in it .
[Re: JohnRR]
#1169940
02/02/12 12:32 PM
02/02/12 12:32 PM
scratchnfotraction
CC.
would 5 qrts of STP be enuff ZDDP?
I have used 2-3 qrts to quiet the rod knock down before..be me thinks it was a little to late at the time for ZDDP to save it.
[Re: dogdays]
#1169942
02/02/12 12:50 PM
02/02/12 12:50 PM
JohnRR
U.S.S.A.
For a stock 360? Guys, get real. Stock valve springs that have way less than 100# seat pressure, already broken in, with a .4" lift cam? Whatever oil you buy will have plenty of lubrication power. There are literally millions of flat tappet stock engines running around using whatever oil Grease Monkey puts in with no failures.
Find something more important to worry about. Like the high price of arugula at your local grocer's (No_Politics reference).
R.
[Re: scratchnfotraction]
#1169943
02/02/12 12:51 PM
02/02/12 12:51 PM
JohnRR
U.S.S.A.
CC.
The zinc is for the cam and lifters not the bearings.
[Re: larrymopar360]
#1169944
02/02/12 12:59 PM
02/02/12 12:59 PM
Posts: 152 MA
1968 Charger B5
MA
I tend to run VR-1 in my cars, 20w-50 during hot months... OR rotella...
However...I will say one thing.... I have an 87 Ramcharger that I installed a rebuilt 440...when i broke the engine in I did the usual...run at different rpms for 1/2 hour holding, and used straight30w detergent oil....HOWEVER, since then, it gets whatever cheap-ass-shitty oil I can buy on discount from whatever store....it was my daily driver from 98-07 with that engine....now its a plow truck, but the engine starts and runs just fine...all this zinc talk...and the cheap oil never had ANY effect on the 440.....maybe its just a testament to how great Mopar engines are...
Rick
1968 Dodge Charger R/T 1971 Plymouth Roadrunner 1998 Jeep Cherokee
[Re: JohnRR]
#1169946
02/03/12 07:39 PM
02/03/12 07:39 PM
scratchnfotraction
CC.
you didnt get it did you John?
#1169947
02/04/12 04:30 AM
02/04/12 04:30 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If a little zinc additive won't hurt it I would rather have it for extra peace of mind. It is a high mileage stock E58. I would feel better with it. Mike: I am going to run a fuel system cleaner thru it too, thanks.
[Re: larrymopar360]
#1169948
02/04/12 08:36 PM
02/04/12 08:36 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I'd be willing to bet any diesel oil will have plenty ZDDP in it for a stock 360.
Rotella synthetic blend?
I bought a bunch of STP oil stabilizer. (no longer made) Nothing to use it in right now.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: larrymopar360]
#1169950
02/05/12 05:58 PM
02/05/12 05:58 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Thanks.
The cheapeast wallmart brand oil available today is lightyears ahead of the best oil in the 70s/80s/ most of the 90s. Imo, I wouldn't worry about adding zinc. Especially in a hydraulic cammed engine.
