Page 3 of 5 1 2 3 4 5
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tboomer] #1166537
01/29/12 03:46 PM
01/29/12 03:46 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Here are some gasket-to-manifold port window matches. The smaller,RED gasket is a Superformance gasket for stock port windows. The BLACK gasket is the Hughes Oversized gaskets,for ported heads...they are a near-perfect match to the cnc'd heads...but looks like I'll be doin' some whittling,when using these Hughes gaskets!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166538
01/29/12 03:47 PM
01/29/12 03:47 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
HUGHES GASKET MATCH!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166539
01/29/12 04:06 PM
01/29/12 04:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Randy I used the Mopar gray RTV sealer I got from the Dealer I used to work at and it has not leaked or seeped at all. Ron
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: 383man] #1166540
01/29/12 04:10 PM
01/29/12 04:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This pic was taken in December at a car show and as you can see it has not leaked at all. The gray Mopar sealer says for Eng and Drivetrain sealing. This is after I have put 7 passes on it at the track and about 1000 street miles. Ron
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166541
01/29/12 05:55 PM
01/29/12 05:55 PM
Tennessee
Charger4404spd Offline
Tennessee
Kenny...I'm with George! If you make one with the center recess,for dual-plane manifolds,it would accomadate BOTH types of manifolds! I have an RPM Performer dual-plane that I wouldn't mind trying out in the future! Right now an M-1 is my manifold of choice!
I agree! I am glad it was brought up, I didn't even think of it, almost all the B and RB engine we do have an M1 or victor intake on them.
BTW, I just did a flat plate for a 608 hemi dad just did and it seals completely.
Adding the recess in the plate will add expence to it, but I will try to make one for a good price. Of course, I will have a price together for them BEFORE I make any, and that price will be set in stone.
-Kenny
I'd like one of the recessed plates!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Charger4404spd] #1166542
01/29/12 06:12 PM
01/29/12 06:12 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Kenny and Randy,
i would be interested in a flat one for my motor.
i would not want to have to remove a head to fit it like with the indy plates
maybe you could set up for a low deck as well?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tex013] #1166543
01/29/12 06:27 PM
01/29/12 06:27 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Cool! I do plan on making B and RB plates for sure. I need to make a small block 9.200" deck one at the same time too. The plate will be removable with out pulling the heads
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166544
01/29/12 07:57 PM
01/29/12 07:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i used the indy plate with the removeable center plate. i cut off the tapered sides & filled the gap with high torque silicone. never ever had a seep or leak. go a plate for my sb from the scrap yard. cut & fit the same as the indy plate. no leaks or seeps. simple & cheap
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: rickraw] #1166545
01/29/12 08:14 PM
01/29/12 08:14 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I have always been surprised that no one makes one for the rpm heads either. I'm not a big fan of the factory pan. I'm running the hughes 2 piece. But I have a few leaks to deal with. I think their design would be ok with a thicker gauge metal.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: 70VcodeCoronetRT] #1166546
01/29/12 08:40 PM
01/29/12 08:40 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the tip on using the grey RTV,Ron! I prefer a little contrast in colors on my motor...but yours is immaculately CLEAN! Tim...I've heard more than a few complaints of the Hughes plate's leaking...maybe that's why they're discontinued!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166547
01/29/12 08:41 PM
01/29/12 08:41 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Kenny if you do make some plates, post the info. I will buy one for a 440.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Azzkikrcuda] #1166548
01/29/12 08:43 PM
01/29/12 08:43 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny..who's got 1st "dibs" on the prototype???
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tex013] #1166549
01/29/12 09:03 PM
01/29/12 09:03 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
I would be interested in a flat one for my 440 motor.
I would not want to have to remove a head to fit it like with the Indy plates.
Would these be a 1, or 2 piece plate??
What price range would these be in??
Can you get a picture when you get one made??
"I've upped my horsepower, so...... UP YOURS!!!"
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166550
01/29/12 09:56 PM
01/29/12 09:56 PM
Saskatchewan, Canada
barracudabob Offline
Put me on the list, flat one for RB. Thanks, Bob
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: barracudabob] #1166551
01/29/12 10:31 PM
01/29/12 10:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i am completely baffled why more guys dont spend $220 for one of the best BB intakes made. and then complain about mopar prices to high
the 337 would do everything you need
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: sixpackgut] #1166552
01/29/12 11:01 PM
01/29/12 11:01 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well I guess every other intake should be destroyed for scrap then if there is only one intake for every single engine combo ever made
Gus
64 Plymouth Savoy
Dana 60
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: sixpackgut] #1166553
01/29/12 11:04 PM
01/29/12 11:04 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
thats why i have 4 of them. my last 500" rebuild made 718 hp, and i can close the stock hood, even with a 1/2" spacer...
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: fourgearsavoy] #1166554
01/29/12 11:07 PM
01/29/12 11:07 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Gus
for the combo in this thread, i agree. melt them down
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: sixpackgut] #1166555
01/29/12 11:27 PM
01/29/12 11:27 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
aren't they max wedge port only ? if so won't help stock port motors
Tex
New best MPH 130.32
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tex013] #1166556
01/29/12 11:32 PM
01/29/12 11:32 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Tex
the 337 is a very small MW size with lots of meat. the heads in this thread are larger than stock anyway. and its only aluminum so it not very difficult to make it work
