Page 2 of 5 1 2 3 4 5
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166517
01/28/12 06:30 PM
01/28/12 06:30 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny..looks like a nice Shivvy! I like the lowered stance,also!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166518
01/28/12 07:16 PM
01/28/12 07:16 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i'm with you Randy,i'd like to see a plate to truely suit stealth eddy heads
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tex013] #1166519
01/28/12 07:43 PM
01/28/12 07:43 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Tex
So how many of these am I doing then?
I agree there is a need for good valley plates.
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166520
01/28/12 08:03 PM
01/28/12 08:03 PM
Queensland,Australia
T-bar Offline
T-bar  Offline
Hey Labratt i was chasing one for mine last year and could only come up with the two piece stainless one from Mancini fits good seals up ok the only thing i changed was the center screws. Imo they didn't take up right so i got some little nuts welded to the bottom side and put allen key headed bolts through the top. Looks good tightens and seals better than the self tapping screws that were supplied.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: T-bar] #1166521
01/28/12 08:35 PM
01/28/12 08:35 PM
Central NC
gch Offline
gch  Offline
Central NC
Make a version with the dimple for the dual plane intakes and I will buy both.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: gch] #1166522
01/28/12 10:01 PM
01/28/12 10:01 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny...I'm with George! If you make one with the center recess,for dual-plane manifolds,it would accomadate BOTH types of manifolds! I have an RPM Performer dual-plane that I wouldn't mind trying out in the future! Right now an M-1 is my manifold of choice!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166523
01/28/12 10:09 PM
01/28/12 10:09 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Here are a few pics of the Hughes over-sized port window intake gaskets, attached to one of my heads. A near-perfect fit,as far as port window is concerned! Just have to trim about .160 off the bottom of the gasket..where it hangs past the deck surface.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166524
01/28/12 10:11 PM
01/28/12 10:11 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
ANOTHER
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166525
01/28/12 10:13 PM
01/28/12 10:13 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
ON THIS PIC,YOU CAN SEE THE OVER-HANG THAT NEEDS TRIMMING.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166526
01/28/12 11:33 PM
01/28/12 11:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice looking gasket.
I used one of these to trim the port areas up on the sheet metal:
Then I used all 4 of the paper gaskets that come with the 1214 fel pro kit.
Rich H.
Esse Quam Videri
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166527
01/29/12 12:00 AM
01/29/12 12:00 AM
Alberta Canada
Alberta Canada
I agree! I am glad it was brought up, I didn't even think of it, almost all the B and RB engine we do have an M1 or victor intake on them.
BTW, I just did a flat plate for a 608 hemi dad just did and it seals completely.
Adding the recess in the plate will add expence to it, but I will try to make one for a good price. Of course, I will have a price together for them BEFORE I make any, and that price will be set in stone.
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166528
01/29/12 01:16 AM
01/29/12 01:16 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Sounds good,Kenny! Now aren't ya' glad I started this post...and interest in an Indy-type plate for us non-Indy head owners? SOMEONE with the know how..and equipment to produce these at a competitive price,could stand to make some coin...if the demand is there for them!...which I believe IS! Keep us in the loop on your progress,Kenny! Looking forward to hearing from you!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166529
01/29/12 01:26 AM
01/29/12 01:26 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Randy If you do go with a plate and a Performer RPM you will have to cut the heat stove off the bottom of the intake so it will fit.It looks like you could make a nice ashtray out it after you cut it off
Gus
64 Plymouth Savoy
Dana 60
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: fourgearsavoy] #1166530
01/29/12 02:07 AM
01/29/12 02:07 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
ASHTRAY??!!! Gus...too bad I don't smoke!..NOT REALLY! I hate cigarettes! I won't cut the heat cross-over off of my RPM manifold..that's why I'm trying to get my buddy from North of the border(Kenny Joss)"StrokerAspen" to fabricate one for me..which I think he will do! Smart young man,and a real go-getter,that guy is! Gus..Nick was suppose to give my K-1's a good going-over before shipping them! I thought I'd see them today,but looks like early next week! Thanks again for making that happen!..I owe you!..AGAIN!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166531
01/29/12 03:02 AM
01/29/12 03:02 AM
Alberta Canada
Alberta Canada
Thanks Randy for the kind words. I will do what I can!
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166532
01/29/12 03:09 AM
01/29/12 03:09 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
I had a 1/8" plate welded to the bottom of the manifold when I ran the RPM heads and was leak proof too.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: TC67CUDA] #1166533
01/29/12 11:37 AM
01/29/12 11:37 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Tony..looks REAL NICE! BOTH,the plate installation....and your engine..and engine bay! That's 3!...my counting ability is starting to diminish..OLD AGE? I better NOT forget how to read my mics..and dial bore indicator...when I start putting this 440 back together!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166534
01/29/12 12:59 PM
01/29/12 12:59 PM
tboomer Online work
tboomer  Online Work
Randy....Have you port matched you intake to the heads yet?
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tboomer] #1166535
01/29/12 01:17 PM
01/29/12 01:17 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Hi,T-Boom! No..not yet! I'm sure you saw my pics of the port window-to gasket match with the Hughes gasket. ...SPOT-ON!..sizing is pretty much perfect! I just have to trim approx. .160 off the bottom of the gasket,where it overhangs the head deck surface. Do you have a technique for intake manifold-to-head port matching,that you want to share? I'm ALL ears! BTW...I'll post a few pics of the Hughes gasket-to M-1 port window match-up,in a short while!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166536
01/29/12 01:19 PM
01/29/12 01:19 PM
tboomer Online work
tboomer  Online Work
Not much help to ya...Was just curious!! I won't see my heads for a while..
