Page 1 of 4 1 2 3 4
its winter...so how about a "what will it make" post... #1166401
01/27/12 11:13 PM
01/27/12 11:13 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
actually....more like a "what did it make" post.
its a motor i did for a friend of mine last spring.
some of you already know the numbers......so you guys cant play
the plan was for a relatively low RPM BB that would run on mixed gas, and be low maintenance, and run 10.0's at 3450lbs in the summer heat.
the original plan was going to be based on a stock 440 block bored .030 over with a 4.250 crank, for 505ci.
then, the decision was made to use an aftermarket block.
once that decision was made, then it didnt really make sense to stay with 505ci.
i decided on a 4.440 bore with a 4.375 stroke.....542ci.
then, it was deemed worth the extra $$$ to lose the 150lbs by using an aluminum block rather than a heavyweight World iron piece(over 300lbs).
so, its an Indy block, 4.440 bore
*eagle 4.375 crank
*eagle 7.100 rods
*custom Diamond inverted dome pistons, 11.7cr
*plain, old, boring 1/16, 1/16, 3/16 ring pack, std tension oil rings
*EZ-1 heads, chambers ported, bowls blended, valve job, flow 340/230
*roller cam, 272/278-112, .650/.630 lift
(the heads and cam actually were used parts that came from Mark Gates 511 Pacer motor)
*HS 1.5 rockers
*older, non-HP 1050 3 circuit dominator(also from Marks 511)
*440-3 intake
*Hooker 1 7/8" fenderwell headers(long), 3.5" collectors
*center sump deep pan with single line external system
then.....its going in a 3450lb Dart with ladder bars and 30X10.5 radial drag slicks, 4.10 gears and an ATI 8" converter.
lets hear what you got to say.....
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166402
01/27/12 11:17 PM
01/27/12 11:17 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
760-780hp
10.30 10.40s
1.39 9.85 - 137 mph
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166403
01/27/12 11:19 PM
01/27/12 11:19 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Sounds like it should solidly be in the 14's, maybe a high 13 with some tuning. .....ok...ok...I cant play. Now I'm bored.
RIP Monte Smith
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166404
01/27/12 11:33 PM
01/27/12 11:33 PM
The 440-3 intake is M.W. port size so I'm assuming the heads are to, aluminum block deduct 30 HP so I'm guessing between 800 and 820 HP at or close to 7000 RPM
Re: its winter...so how about a "what will it make" post... [Re: Ari440] #1166405
01/27/12 11:35 PM
01/27/12 11:35 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
evrything similar to my motor except for the cubes and my challenger goes 6.20s at 110mph at over 3500lbs with full exhaust on the car in the 1/8th
so bigger bore, that engine goes 750hp and that car is mid 9s
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166406
01/28/12 02:10 AM
01/28/12 02:10 AM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
[Email]767hp@6500[/Email]
[Email]712lbs@5000[/Email]
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166407
01/28/12 02:19 AM
01/28/12 02:19 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It's 80plus during the day you call that winter? I'd like more info to make more than a WAG. If it only runs 10's you got a tune up problem.Good to see you around.
Re: its winter...so how about a "what will it make" post... [Re: Ari440] #1166408
01/28/12 02:24 AM
01/28/12 02:24 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
are the 1 7/8 headers small?
9.90 -10.10 is what I would say. and 745hp
Re: its winter...so how about a "what will it make" post... [Re: 70blackfish] #1166409
01/28/12 03:38 AM
01/28/12 03:38 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Either these hp numbers are high for the et predictions or...? I doubt my junk makes 700 and its running 10.0s at 100lb heavier..
FWIW I think 9.90 to 10.10 would be a good guess, although the displacement may help get the car moving quicker so it may dip into the 80s. You have more duration but the displacement should eat that up.
Re: its winter...so how about a "what will it make" post... [Re: Kevins493] #1166410
01/28/12 08:35 AM
01/28/12 08:35 AM
tboomer Offline
tboomer  Offline
My guess is around 785...Hmmm...Mark Gates..How is he doing,Dwayne? Haven't heard that name in a long time!! Does he still have his fishbowl??
Re: its winter...so how about a "what will it make" post... [Re: tboomer] #1166411
01/28/12 11:34 AM
01/28/12 11:34 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Did the heads have the platinum series port work done to them ?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: its winter...so how about a "what will it make" post... [Re: Dap] #1166412
01/28/12 12:16 PM
01/28/12 12:16 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Stage 3
760 HP
Re: its winter...so how about a "what will it make" post... [Re: fast68plymouth] #1166413
01/28/12 12:19 PM
01/28/12 12:19 PM
NC
440Jim Offline
440Jim  Offline
NC
As I read the engine combo it sounded like a good, conservative combo...
Then I saw those tiny and long headers on a 542 CID
I would love to see the dyno difference between those headers and your stepped 2 to 2-1/8" dyno headers.
So I am thinking 690 hp at a low peak rpm ~6200, but it might not fall off too bad. I hope it makes more.
I wish I knew what Mark Gate's engine made, since the heads are from that engine.
Re: its winter...so how about a "what will it make" post... [Re: Ari440] #1166414
01/28/12 12:30 PM
01/28/12 12:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Guesses so far:
Ari440 760-780hp
Cab Burge 800-820 HP
sixpackgut 750hp
GwaiiEagle [Email]767hp@6500[/Email]
70blackfish 745hp
Kevins493 ? less than 700 ?
tboomer 785
S/ST 3040 760 HP
440Jim 690 hp at a low peak rpm ~6200
Re: its winter...so how about a "what will it make" post... [Re: 440Jim] #1166415
01/28/12 12:48 PM
01/28/12 12:48 PM
sweden
sshemi Offline
sshemi  Offline
sweden
730 @ 6600
Re: its winter...so how about a "what will it make" post... [Re: sshemi] #1166416
01/28/12 12:57 PM
01/28/12 12:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i'll guess 710 but I agree with Jim
Re: its winter...so how about a "what will it make" post... [Re: Quicktree] #1166417
01/28/12 01:14 PM
01/28/12 01:14 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'll say 720 at 6200, the combination of the small exhaust tubes ( collector size is 3.5 so it's probably not quite as bad as it looks ) and EZ-1's built-in 'kinda meh' exhaust flow (compared to a raised port) is going to force the peak RPM to be a tad to the low side, peak torque should come in around 5000 but with the cubes and CR it should be EPIC all the way there. The wider 112 centers should help the torque hang on a while though. An exhaust limited low Peak torque RPM has a way of lowering the HP curve trajectory, but there's F.A.S.T. ways of getting the torque not to drop like a stone.
The guess is on the high side for most but I know Dwayne knows how to make the most of that EZ intake port.
I was gonna ask why not use a raised port but then I realized you probably are dealing with something that might have to fit back into a Fishbowl
WIZE
In Car:
Re: its winter...so how about a "what will it make" post... [Re: Streetwize] #1166418
01/28/12 01:23 PM
01/28/12 01:23 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
I've seen the car run and it leaves real hard (3-4ft wheelstands) and 60fts very well for the weight. You'll be surprised at the power numbers VS ET's for this beast.
I know what it made so i can't play
Ron
Re: its winter...so how about a "what will it make" post... [Re: Ari440] #1166419
01/28/12 01:27 PM
01/28/12 01:27 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
760-780hp
10.30 10.40s
It better go 9.70's at least in a 3450 pound car or the stuff should all be thrown in the garbage can. A small block with that compression and that good of head would run that
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: its winter...so how about a "what will it make" post... [Re: B3422W5] #1166420
01/28/12 02:12 PM
01/28/12 02:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My guess would be right around 700 hp. Ron
Page 1 of 4 1 2 3 4
