its winter...so how about a "what will it make" post...
#1166401
01/27/12 11:13 PM
01/27/12 11:13 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
actually....more like a "what did it make" post. its a motor i did for a friend of mine last spring. some of you already know the numbers......so you guys cant play the plan was for a relatively low RPM BB that would run on mixed gas, and be low maintenance, and run 10.0's at 3450lbs in the summer heat. the original plan was going to be based on a stock 440 block bored .030 over with a 4.250 crank, for 505ci. then, the decision was made to use an aftermarket block. once that decision was made, then it didnt really make sense to stay with 505ci. i decided on a 4.440 bore with a 4.375 stroke.....542ci. then, it was deemed worth the extra $$$ to lose the 150lbs by using an aluminum block rather than a heavyweight World iron piece(over 300lbs). so, its an Indy block, 4.440 bore *eagle 4.375 crank *eagle 7.100 rods *custom Diamond inverted dome pistons, 11.7cr *plain, old, boring 1/16, 1/16, 3/16 ring pack, std tension oil rings *EZ-1 heads, chambers ported, bowls blended, valve job, flow 340/230 *roller cam, 272/278-112, .650/.630 lift (the heads and cam actually were used parts that came from Mark Gates 511 Pacer motor) *HS 1.5 rockers *older, non-HP 1050 3 circuit dominator(also from Marks 511) *440-3 intake *Hooker 1 7/8" fenderwell headers(long), 3.5" collectors *center sump deep pan with single line external system then.....its going in a 3450lb Dart with ladder bars and 30X10.5 radial drag slicks, 4.10 gears and an ATI 8" converter. lets hear what you got to say.....
Re: its winter...so how about a "what will it make" post...
[Re: fast68plymouth]
#1166403
01/27/12 11:19 PM
01/27/12 11:19 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Sounds like it should solidly be in the 14's, maybe a high 13 with some tuning. .....ok...ok...I cant play. Now I'm bored.
RIP Monte Smith
[Re: Ari440]
#1166405
01/27/12 11:35 PM
01/27/12 11:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
evrything similar to my motor except for the cubes and my challenger goes 6.20s at 110mph at over 3500lbs with full exhaust on the car in the 1/8th
so bigger bore, that engine goes 750hp and that car is mid 9s
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1166406
01/28/12 02:10 AM
01/28/12 02:10 AM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
[Email]767hp@6500[/Email] [Email]712lbs@5000[/Email]
[Re: 70blackfish]
#1166409
01/28/12 03:38 AM
01/28/12 03:38 AM
Posts: 2,379 MD
Kevins493
MD
Either these hp numbers are high for the et predictions or...? I doubt my junk makes 700 and its running 10.0s at 100lb heavier.. FWIW I think 9.90 to 10.10 would be a good guess, although the displacement may help get the car moving quicker so it may dip into the 80s. You have more duration but the displacement should eat that up.
#1166413
01/28/12 12:19 PM
01/28/12 12:19 PM
Posts: 16,923 NC
440Jim
NC
As I read the engine combo it sounded like a good, conservative combo...
Then I saw those tiny and long headers on a 542 CID I would love to see the dyno difference between those headers and your stepped 2 to 2-1/8" dyno headers.
So I am thinking 690 hp at a low peak rpm ~6200, but it might not fall off too bad. I hope it makes more. I wish I knew what Mark Gate's engine made, since the heads are from that engine.
[Re: 440Jim]
#1166415
01/28/12 12:48 PM
01/28/12 12:48 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: Quicktree]
#1166417
01/28/12 01:14 PM
01/28/12 01:14 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
I'll say 720 at 6200, the combination of the small exhaust tubes ( collector size is 3.5 so it's probably not quite as bad as it looks ) and EZ-1's built-in 'kinda meh' exhaust flow (compared to a raised port) is going to force the peak RPM to be a tad to the low side, peak torque should come in around 5000 but with the cubes and CR it should be EPIC all the way there. The wider 112 centers should help the torque hang on a while though. An exhaust limited low Peak torque RPM has a way of lowering the HP curve trajectory, but there's F.A.S.T. ways of getting the torque not to drop like a stone. The guess is on the high side for most but I know Dwayne knows how to make the most of that EZ intake port. I was gonna ask why not use a raised port but then I realized you probably are dealing with something that might have to fit back into a Fishbowl
