Lets talk Solid vs. Hydraulic cams
#116528
09/07/08 12:35 PM
09/07/08 12:35 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Still playing with cam choice in a street / strip 451. For a car thats going to weekend duty and the drag strip 4-6 times a year, what would be your choice?, and why?
Re: Lets talk Solid vs. Hydraulic cams
[Re: topside]
#116530
09/07/08 01:01 PM
09/07/08 01:01 PM
StealthWedge67
Puyallup, WA
I like to tinker in the garage & don't mind adjusting the lash a few times a year, so that doesn't bother me. I already have a set of adjustable rockers, so there's no issues there. What about engine reliablility? Just ran a few cams through CamQuest. To no suprise, a smaller solid makes a little more HP and way more torque, what did suprise me was that the peak HP was made lower in the RPM band (5500 w/ the XS274S vs 6000 w/ the XE285HL). Peak Torque and HP falling within 1500 RPM of each other looks pretty good!
[Re: StealthWedge67]
#116531
09/07/08 01:51 PM
09/07/08 01:51 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
Solids make power & rpm. Maintenance on mild streetable grinds shouldn't be a problem either. In the past I've used solids in both wedge and Hemi engines without any problems. Now we have new issues to consider that we didn't have years ago. Flat tappets solid or hydraulic are failing much more often than they used to. Rollers are the obvious solution to this problem, but I have real doubts about solid rollers having 100,000 mile plus reliability, which is my personal definition of true streetablity. I think that even with relatively weak spring pressures the axle bearings on a solid roller will be hammered pretty hard due to the required valve lash. OEM hydraulic rollers on the other hand have proven to have good long term reliability. Aluminum heads, we didn't have them years ago. Now we do and they're great. Light weight, good flow OTB, easy to repair, less time involved in porting etc. They also expand and contract more than the iron blocks they're bolted to. This of course affects valve lash. I don't think that this is a real big deal, but it is one more argument in favor of hydraulics. I am presently using a Comp 284 xe flat tappet hydraulic in my aluminum headed small blk. I expect it will be the last flat tappet cam I'll ever use. Next time, hydraulic roller.
[Re: 1_WILD_RT]
#116534
09/07/08 02:24 PM
09/07/08 02:24 PM
StealthWedge67
Puyallup, WA
there is one issue... I run Pro-Comp stainless roller-tip rockers that have oiling provisions through the pushrods. the adjuster stud is machined for oil passage, and oil into the rocker assembly. is there any such thing as an oil through solid lifter?
#116536
09/07/08 02:29 PM
09/07/08 02:29 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I will go with a Hydraulic. The new grinds of hydraulics and lifter design have changed the RPM range so that valve float & lifter pump up doesn't happen at nearly as low an RPM as it used to. As for hundred thousand mile rollers, they probably would but not with the spring pressures and cam profiles run in these engines. Any way who has to worry about that kind of miles on these cars that are being built will never see close to that. In my first sentence I should have said that I would go with a hydraulic if I were to build another engine which is very doubtful. In fact I am very close to advertising the car and trailer for sale and getting out of it all together. Only went to 2 show this summer and didn't miss it in the least. Maybe if I were feeling better I would but haven't felt like doing anything and having to settle for doing just that. But Yeah come early spring I think that the package will be for sale.
#116537
09/07/08 02:39 PM
09/07/08 02:39 PM
StealthWedge67
Puyallup, WA
Lets not even consider rollers, Hyd. or solid. It's just not in the budget.
[Re: topside]
#116538
09/07/08 02:48 PM
09/07/08 02:48 PM
All of the OEM's have gone to roller cams. This has caused the oil producers to eliminate Zink. Zink is hard on Cat converters but is nesacary for lubrication on solid lifters. Rotella was the last producer to include Zink. And that was supposed to be discontinued in 08. Trust me I learned this the hard way.
[Re: solidcam]
#116541
09/07/08 04:02 PM
09/07/08 04:02 PM
MoparforLife
Upper Midwest
This is a no brainer.A solid cam is giong to outperform a hydrualic any day.Tests have shown increases over a Hydrualic of the same duration and lift with compensation for lash and other factors.Did you go to all the effort to build your performance engine to sacrifice power? At the point where a Hydrualic falls off the solid keeps going.If you want to go aggressive without going solid-roller you can even look at a Mushroom cam.
Not nessessarly. A solid cam with the same lift and duration specs will be a lesser cam than the hydraulic and performance will show it. A .528 solid will be about equal to a 509 after lash is figured in.
[Re: MoparforLife]
#116544
09/07/08 07:06 PM
09/07/08 07:06 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
In fact the 509 will out perform the 528 in many cases.
What way is that?? Certainly not performance wise...Maybe in poor idle quality..
Sorry the 509 has never particularly impressed me..
[Re: mike s]
#116546
09/07/08 07:42 PM
09/07/08 07:42 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The 509 will make more H.P. and less torque than the 528 in an engine with a real 10-10.5 comp ratio.If it's too low the .509 is a just a noise maker.The latest .509 and the .484 with the revised LC have much better street manners.
The last engine I built with a 509 was 20+ years ago, forged TRW sixpack pistons, 915 heads, a true 10.5 motor...The 509 was such a dog down low I put Rhoades lifters on it which helped tremedously but it sounded like a race boat the lifters were twice as loud as a well adjusted solid lifter....
I've taken 509 cams out of four cars & only installed two, both times I felt there were better cams out there....
