EFI Kit For Blower ? #1164683
01/25/12 07:01 PM
01/25/12 07:01 PM
York,NE
WOTcuda Offline OP
WOTcuda  Offline OP
York,NE
Does Any One Have Suggestions For Running Two EfI Instead Of Carbs On 360 W/Blower?
Re: EFI Kit For Blower ? [Re: WOTcuda] #1164684
01/25/12 07:12 PM
01/25/12 07:12 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
Check out FAST EFI, they have a 2 X 4 kit
http://www.fuelairspark.com/ezefi/default.asp
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: EFI Kit For Blower ? [Re: 00snake530] #1164685
01/25/12 08:40 PM
01/25/12 08:40 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The dual throttle body EZ system from FAST does not support boosted engines. But the FAST self learning XFI 2.0 would be a perfect fit. But you'd need a laptop for setting the basic parameters .
Re: EFI Kit For Blower ? [Re: Mopar_Rich] #1164686
01/25/12 08:47 PM
01/25/12 08:47 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
Good call, 1 bar map on the ez system
00 Viper gts
15 Escalade (daily)
Re: EFI Kit For Blower ? [Re: 00snake530] #1164687
01/25/12 09:02 PM
01/25/12 09:02 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
Throttle bodies? What are those?
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: EFI Kit For Blower ? [Re: VZCharger] #1164688
01/25/12 11:11 PM
01/25/12 11:11 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The bug catcher set-up with FAST XFI or FAST Classic efi works well in either blown or unblown modes....
Re: EFI Kit For Blower ? [Re: WOTcuda] #1164689
01/26/12 03:05 PM
01/26/12 03:05 PM
I see no reason you couln't run dual dry throttle bodys with one TPS or a MAP sensor Anyone else, Rich?
Re: EFI Kit For Blower ? [Re: Cab_Burge] #1164690
01/26/12 03:15 PM
01/26/12 03:15 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I don't think the fast ez kit has fueling or timing maps for the engine under boost. (never saw it just guessing)
I'm sure with enough tinkering you could get it to work but by then just buy the correct box and have at it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: EFI Kit For Blower ? [Re: bigtimeauto] #1164691
01/26/12 05:05 PM
01/26/12 05:05 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I was thinking of getting just the hardware from the Dual TB EZ EFI, and then using a different ECU to run it.
I heard that the bug catcher type of setups get touchy for street driving.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: EFI Kit For Blower ? [Re: kick_the_reverb] #1164692
01/26/12 05:22 PM
01/26/12 05:22 PM
Dragula Offline
Dragula  Offline
Ran
Yes they are. When you consider the surface area exposed vs. the amount of throttle imput between them, yes touchy, but for the street, I restrict the fuel a little and it calms it down. I have two programs, one for racing, and one for street driving. Especially if you uncork it for racing!
Re: EFI Kit For Blower ? [Re: Dragula] #1164693
01/26/12 06:14 PM
01/26/12 06:14 PM
York,NE
WOTcuda Offline OP
WOTcuda  Offline OP
York,NE
Thanks Guys . I'll Make Some Phone Calls . Was Hopeing For A Self Controlled unit That would Adjust itself . I'LL Do Some More Checking.
Re: EFI Kit For Blower ? [Re: WOTcuda] #1164694
01/26/12 08:25 PM
01/26/12 08:25 PM
Sounds like it is time for Big Stuff Three I bought some parts on here(dual 4150 throttle bodys) recently for a Rons mechanical methanol fuel injection based on wanting to convert it to use with E85, no EFI on it. I'm thinking, hoping, you can mix and blend some parts like the dry throttle bodies with some EFI parts, like the injectors,fuel rails, MAP, TPS, main controller(brain) and so on we will see, Rons wanted over $900.00 to convert the pump and injectors and add two primers for it to start on gasoiline I already have some 80 lb EFI injectors that came with those parts so maybe it is time to convert and stop fighting progress
Re: EFI Kit For Blower ? [Re: WOTcuda] #1164695
01/26/12 10:28 PM
01/26/12 10:28 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The XFI 2.0 is self tuning so it does adjust itself, but you still need a laptop to set things such as idle AF, timing, target AF under boost etc., that are not part of the self adjustments. Dual throttle bodies and the XFI (or Big Stuff) is really what you need.
Re: EFI Kit For Blower ? [Re: Mopar_Rich] #1164696
01/27/12 01:48 PM
01/27/12 01:48 PM
York,NE
WOTcuda Offline OP
WOTcuda  Offline OP
York,NE
DO They Have A Web Site For (Big Stuff ) W/Technical Help?
