Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Tobbe] #116376
09/08/08 06:34 AM
09/08/08 06:34 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Mine!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Dartsport540] #116377
09/08/08 09:09 AM
09/08/08 09:09 AM
Real simple on mine. Angle-iron frames on the bottom.
Re: Batteries in the trunk pics - POST YOUR PICS! #116378
09/08/08 07:49 PM
09/08/08 07:49 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I just used two holes that were already in the trunk and a piece of flat aluminum.
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: STLDuster] #116379
09/08/08 09:07 PM
09/08/08 09:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yeah I know it is on the left side but that is where it works and the car hooks and runs straight with it there.
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: MoparforLife] #116380
12/31/08 01:43 AM
12/31/08 01:43 AM
United States
STLDuster Offline OP
United States
WHAT SIZE CABLE DID YOU GUYS USE?
I found some 2Ga american made welding cable tonight for $2.09 a foot. I was thinking about picking up about 10' of for a ground wire. I wasn't sure if I should use a heavier gauge wire for the positive cable from the battery in the trunk to the starter or not. What do you guys think?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: STLDuster] #116381
12/31/08 03:26 AM
12/31/08 03:26 AM
I used a piece of #1 for the positive and two # 2 in the trunk for the grounds, I also use two or more #4 grounds to the frame from the engine as well as the aluminum elephant ears. You can never have to many grounds on a race car with the battery in the trunk
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Cab_Burge] #116382
12/31/08 11:03 AM
12/31/08 11:03 AM
United States
United States
Wow, I think I read your mind, Thats pretty much what I was planning on doing but I wasn't too sure if the 1Ga cable was going to be overkill. I knew most of the cable kits Summit sells are a rip off.
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Cab_Burge] #116383
12/31/08 11:26 AM
12/31/08 11:26 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Ditto here too. Separate ground to the motor, pickup points on the body, steel is a poor conductor of electricity. Copper is much better
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Kevins493] #116384
12/31/08 12:49 PM
12/31/08 12:49 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: STLDuster] #116385
12/31/08 03:01 PM
12/31/08 03:01 PM
United States
United States
I just called up my local welding shop and found 1ga Welding cable (Box of 25') for $62.25, I think I am going to pick up some of the 2ga for a ground(s) and run the 1ga from the battery to the starter.
Sound like a plan? So far thats the best price on the 1ga I have found.
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: STLDuster] #116386
12/31/08 03:04 PM
12/31/08 03:04 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Use the 1ga for your grounds, the bigger the better!!!!
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Blucuda413] #116387
12/31/08 05:33 PM
12/31/08 05:33 PM
United States
United States
Wahoo! I ran over to AirGas down the road. They had 4 pre-packaged 25' 1Ga Heavy Duty Welding cable sitting off to the side. The best thing about it is that it is American made! It is "Radnor" brand, rated for 105 degrees Celsius (221 degrees fahrenheit)...
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: Blucuda413] #116388
12/31/08 08:25 PM
12/31/08 08:25 PM
SW pa
goldenlancer Offline
SW pa
mine
N/SS
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: goldenlancer] #116389
01/05/09 11:03 AM
01/05/09 11:03 AM
United States
United States
I want to thank everyone, I was able to mount up my battery this weekend and I started working on makeing up the cables and routing them. Thanks again, I am sure I will have lots more questions while I am finishing it up.
Re: Batteries in the trunk pics - POST YOUR PICS! [Re: STLDuster] #116390
01/07/09 04:41 AM
01/07/09 04:41 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
$49 off Ebay - Racing Junk
Main thing to be sure of is that the battery is insulated inside the box from movement and terminal contact with the lid.
