Re: Batteries in the trunk pics - POST YOUR PICS!
[Re: Dartsport540]
#116377
09/08/08 09:09 AM
09/08/08 09:09 AM
Real simple on mine. Angle-iron frames on the bottom. ![](http://i37.tinypic.com/2wm06e0.jpg)
[Re: MoparforLife]
#116380
12/31/08 01:43 AM
12/31/08 01:43 AM
Posts: 1,075 United States
STLDuster
United States
WHAT SIZE CABLE DID YOU GUYS USE?
I found some 2Ga american made welding cable tonight for $2.09 a foot. I was thinking about picking up about 10' of for a ground wire. I wasn't sure if I should use a heavier gauge wire for the positive cable from the battery in the trunk to the starter or not. What do you guys think?
"No great genius has ever existed without some touch of madness." - Aristotle
[Re: Cab_Burge]
#116382
12/31/08 11:03 AM
12/31/08 11:03 AM
STLDuster
United States
Wow, I think I read your mind, Thats pretty much what I was planning on doing but I wasn't too sure if the 1Ga cable was going to be overkill. I knew most of the cable kits Summit sells are a rip off.
[Re: Cab_Burge]
#116383
12/31/08 11:26 AM
12/31/08 11:26 AM
Posts: 2,379 MD
Kevins493
MD
I used a piece of #1 for the positive and two # 2 in the trunk for the grounds, I also use two or more #4 grounds to the frame from the engine as well as the aluminum elephant ears. You can never have to many grounds on a race car with the battery in the trunk
Ditto here too. Separate ground to the motor, pickup points on the body, steel is a poor conductor of electricity. Copper is much better ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: STLDuster]
#116385
12/31/08 03:01 PM
12/31/08 03:01 PM
STLDuster
United States
I just called up my local welding shop and found 1ga Welding cable (Box of 25') for $62.25, I think I am going to pick up some of the 2ga for a ground(s) and run the 1ga from the battery to the starter.
Sound like a plan? So far thats the best price on the 1ga I have found.
[Re: Blucuda413]
#116387
12/31/08 05:33 PM
12/31/08 05:33 PM
STLDuster
United States
Wahoo! I ran over to AirGas down the road. They had 4 pre-packaged 25' 1Ga Heavy Duty Welding cable sitting off to the side. The best thing about it is that it is American made! ![](/ubbthreads/images/graemlins/thumbs.gif) It is "Radnor" brand, rated for 105 degrees Celsius (221 degrees fahrenheit)...
