Analyze my (truck) alignment?
#1162783
01/22/12 07:10 PM
01/22/12 07:10 PM
Posts: 3,897 Oregon
hooziewhatsit
Attached is the print out from the alignment place for my '72 W200 with 32s. I had it checked after I made a new tie rod, so that was the main thing that was being corrected. My main complaint is a little wandering and loose steering at highway speeds. Since it's a solid front axle, is it as simple as adding a ~2* shim to each side to get the caster back into spec? I know it will change the pinion angle, but I'm willing to have a little vibration if it steers better the rest of the time. I've also read that going to ~+4-5* caster with big tires can help a lot as well. Thanks for any thoughts
Re: Analyze my (truck) alignment?
[Re: hooziewhatsit]
#1162784
01/22/12 08:14 PM
01/22/12 08:14 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
Does it have a steering stabilizer? How tight is the steering coupler? How wide are these 32's? I had 31 x 10.50's on an '86 W150 and it followed the road like you are describing. The next set of tires were narrower (265 75 15's) and the truck drove way better. Must have put 3 steering couplers in that thing.......
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1162785
01/22/12 08:20 PM
01/22/12 08:20 PM
Posts: 3,897 Oregon
hooziewhatsit
I want to say the tires are 265/80r16s. Would have to go outside to double check that. I've added a steering stabilizer. Intermediate steering shaft is a newer Borgeson unit. No play between it and the steering shaft. Newer ball joints. New tie rod + tie rod ends. Reduced pressure from the power steering pump. Believe me, I've done about all I can on the steering side. Other than going to a tighter ratio chivy box (which I may still do at some point). But if I can put some shims in and get the caster and steering better...
[Re: hooziewhatsit]
#1162786
01/23/12 10:31 PM
01/23/12 10:31 PM
Posts: 6,008 Salem
Grizzly
Salem
Yep, you nailed all the weak spots.
A straight axle 2Gen Ram holds the road pretty well, would you be able to dig up the alignment specs on one of them? If they are running more caster than the old girls, then you are on the right path. If possible, maybe duplicate those numbers to your truck?
If you do rotate that axle and it vibrates you can always get a CV joint made up. Guys running big lift kits sometimes have to go that route to solve the sharp angle problem.
Mo' Farts
[Re: Grizzly]
#1162787
01/24/12 12:09 AM
01/24/12 12:09 AM
Posts: 3,897 Oregon
hooziewhatsit
Looks like the 2Gen rams were spec'd at 2.5 to 3.5, with 3 being the sweet spot. I also saw somewhere else they recommended 5* for D44s. And finally, I found some guys on ebay who sell 2* or 4* shims that should fit. Decisions, decisions
[Re: ahy]
#1162789
01/24/12 12:50 AM
01/24/12 12:50 AM
Posts: 3,897 Oregon
hooziewhatsit
The caster is low for some reason... springs settled a bit? The pinion angle may be off as well and the shims may even help.
If the springs are reasonable, I'd go ahead and shim it to specs. It will take a fair amount of shim but I'd go ahead and do it. If you do have vibration you can always back off on the shims... but I'd be surprised if you do. For the shims, aluminum is frequently used... but not recommended as it can break down with the high loading it gets. Steel is better.
Also, for stability, you might ask that toe be set with more toe in... within specs but more than what you have. Toe in compensates for the drag of the tires stretching the tie rods and other stuff... with bigger tires, more drag so more toe in. More toe in usually increases stability.
The springs do ride pretty much flat, but I'm not sure how they're supposed to ride either This front (disc brake) axle I swapped in last summer and I just bolted it up to the springs. This is also my plow truck, and the plow is heavy enough it drops the front end by an inch or so when it's up.
Toe I can adjust myself. Any recommendations? 1/8"ish?
ebay shims
[Re: hooziewhatsit]
#1162792
01/24/12 08:28 AM
01/24/12 08:28 AM
Posts: 7,664 IN
ahy
IN
ebay shims
I'd shoot for 3/16" personally.
[Re: hooziewhatsit]
#1162794
01/28/12 02:43 PM
01/28/12 02:43 PM
Posts: 3,897 Oregon
hooziewhatsit
Any last thoughts before I go with 4* shims? Thanks, -Dave
[Re: hooziewhatsit]
#1162795
01/28/12 09:42 PM
01/28/12 09:42 PM
Posts: 6,008 Salem
Grizzly
Salem
Nope. As far as I know it's uncharted territory in your style of truck, so good luck. I'd like to know how this works out; are you gonna update the thread?
Mo' Farts
[Re: hooziewhatsit]
#1162797
09/09/12 12:38 AM
09/09/12 12:38 AM
Posts: 6,008 Salem
Grizzly
Salem
Have you tried tightening the set screw on the steering box?
Not a 100% sure on the procedure, but I believe it's there to take the on center dead spot out.
Mo' Farts
[Re: Grizzly]
#1162798
09/09/12 01:32 AM
09/09/12 01:32 AM
Posts: 3,897 Oregon
hooziewhatsit
Yep, haven't checked it recently, but I did adjust it nice and tight a few years ago. At that time I took off the arm between the pitman arm and the knuckle (name escapes me right now), and found I could rattle the end of the pitman arm 1/16" Took the box out and adjusted it on the bench until it was perfect. It did help some, but not enough to make it tight enough my wife feels safe driving it.
[Re: Grizzly]
#1162799
09/17/12 03:07 AM
09/17/12 03:07 AM
Posts: 3,897 Oregon
hooziewhatsit
Took the truck to a friends place today and got his thoughts on it. We ended up screwing in the set screw by another 3/4 of a turn or so. That seems to have made all the difference. When I adjusted it on the bench, I went until there was zero play in the pitman arm. Apparently I needed to go just a little farther. He was also thinking it made a difference whether it was adjusted while under power or not? But anyways, I think I can check steering off my list of stuff to work on
[Re: hooziewhatsit]
#1162800
09/17/12 08:36 AM
09/17/12 08:36 AM
Posts: 6,008 Salem
Grizzly
Salem
Right on! So is this mission accomplished?
Mo' Farts
