A body steering #1161806
01/21/12 01:16 AM
01/21/12 01:16 AM
Ohio
ralphie361 Offline OP
Ohio
I have a 69 swinger, and a rebuilt newer steering box. If I use the 73 up pitman, idler, and centerlink can I use this box? Any benefits from using the newer steering linkage, or will it even fit? I dont really want to get another K, and would like to use up the box on the shelf.
Re: A body steering [Re: ralphie361] #1161807
01/21/12 01:25 AM
01/21/12 01:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
yes that will work with a larger sector P/S box. I ran that setup on my 68 Barracuda for years.
But I had factory HiPo exhaust manifolds. If you have certain headers and you motor is on the edge of stock position, it may be an issue. Just depends on how much and where you have room.
I have TTI 3/4" stepped headers with that setup and no issues.
Re: A body steering [Re: autoxcuda] #1161808
01/21/12 02:27 AM
01/21/12 02:27 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Just curious, what ratio? I've got a 16:1 box on mine, 73-up pittman/idler/drag link, and no clearance issues with a 3ghemi and TTI headers.
-Daty
Re: A body steering [Re: autoxcuda] #1161809
01/21/12 05:08 PM
01/21/12 05:08 PM
Ohio
Ohio
Thanks!
Re: A body steering [Re: ralphie361] #1161810
01/29/12 09:41 PM
01/29/12 09:41 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Like has been said, it will fit but there might be a bump-steer issue if you don't also use the '73-up steering arms/ball joints. The late center link is wider where the inner tie rod ends attach. If you've already done the late disc brake swap all the better.
