Push Button Shifter Question #1161680
01/20/12 09:09 PM
01/20/12 09:09 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The gear selector cable hole is approx .180" The pin at the shift mechanism is .125" Should there be a bushing in the cable? Any pictures of the retainer or shifter?
Doug
Re: Push Button Shifter Question [Re: dvw] #1161681
01/21/12 05:11 PM
01/21/12 05:11 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If your cable end has a .180" hole it's a console cable or somebody has enlarged the hole; the PB cable has a .125" hole.
The console/PB cable housing ends are also different, in the pic below the PB cable is at the top.
Re: Push Button Shifter Question [Re: John_Kunkel] #1161682
01/21/12 06:23 PM
01/21/12 06:23 PM
Godfrey, Il
muntz1 Offline
muntz1  Offline
Godfrey, Il
I have an original and a custom length cable from Imperial and both measre .125
Re: Push Button Shifter Question [Re: muntz1] #1161683
01/21/12 08:41 PM
01/21/12 08:41 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How was your experience with Imperial??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Push Button Shifter Question [Re: John_Kunkel] #1161684
01/22/12 01:11 AM
01/22/12 01:11 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
My cable looks like the top cable except for the hole. I'll have to make a bushing.
Thanks Doug
Re: Push Button Shifter Question [Re: dvw] #1161685
01/22/12 02:44 AM
01/22/12 02:44 AM
Godfrey, Il
muntz1 Offline
muntz1  Offline
Godfrey, Il
The Imperial cables are excellent quality and work great. I moved the shifter buttons to the left of the steering wheel which required longer cables. They did send two shift cables instead of one shift and one park, but they made it good.
Re: Push Button Shifter Question [Re: muntz1] #1161686
01/22/12 11:36 AM
01/22/12 11:36 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I moved my shifter to the right side of the column for roll bar clearance. The cables are in good shape.
Doug
Re: Push Button Shifter Question [Re: dvw] #1161687
01/22/12 12:53 PM
01/22/12 12:53 PM
Godfrey, Il
muntz1 Offline
muntz1  Offline
Godfrey, Il
Guess I don't know my right from my left. I moved mine to the right also.
Re: Push Button Shifter Question [Re: muntz1] #1161688
01/22/12 12:59 PM
01/22/12 12:59 PM
hemi-itis Offline
hemi-itis  Offline
Seems like a long reach,I put mine on a pedestal on the trans tunnel.
Re: Push Button Shifter Question [Re: hemi-itis] #1161689
01/22/12 01:02 PM
01/22/12 01:02 PM
hemi-itis Offline
hemi-itis  Offline
Here's one that I saw at Lebonon Valley Raceway
Re: Push Button Shifter Question [Re: hemi-itis] #1161690
01/22/12 01:07 PM
01/22/12 01:07 PM
Godfrey, Il
muntz1 Offline
muntz1  Offline
Godfrey, Il
It's not much of a reach when your 6'-6" tall with long arms
Re: Push Button Shifter Question [Re: muntz1] #1161691
01/22/12 07:34 PM
01/22/12 07:34 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Moving the shifter and modifying the drive to 1 button swap was easy. The hard part was the bezel. I agree it may be a reach. We'll see this spring.
Doug
Re: Push Button Shifter Question [Re: dvw] #1161692
01/22/12 08:15 PM
01/22/12 08:15 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
My car is the first I've had with a PB shifter. I assume the buttons on the left is stock, but people move it to the right side. Why? It seems like it would be more natural to push with my right hand, is that why? I was just going to go with a floor shifter, but I may try this for a year or two and see how I like it.
Dennis
Re: Push Button Shifter Question [Re: cudaboy] #1161693
01/22/12 08:50 PM
01/22/12 08:50 PM
Godfrey, Il
muntz1 Offline
muntz1  Offline
Godfrey, Il
Moved mine due to the cage bar. If the bar is in front of the dash you can't get to the buttons, if the bar goes behind the dash it's in the way of the mechanism/cables.
Re: Push Button Shifter Question [Re: dvw] #1161694
01/22/12 09:17 PM
01/22/12 09:17 PM
hemi-itis Offline
hemi-itis  Offline
Doug
That is a real clean install!!
Re: Push Button Shifter Question [Re: muntz1] #1161695
01/22/12 09:21 PM
01/22/12 09:21 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I loved my left side buttons on my 63 Polara. However the stock large diameter wheel can get in the way if the seat has been moved towards the center for cage clearance. I raced a friends that has the seat moved,very uncomfortable. My buttons were moved because the mechanism hit the bar inside the dash.
Doug
