MILIDON SINGLE OIL LINE #1160418
01/18/12 11:12 PM
01/18/12 11:12 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
HELLO
I have a single oil line going to the oilpump to oilpan and it would lose prime after awaile
I loop the oil line over the oilpump and its good now
is this fine the way I have it or could I do better
any pics of your setups
thanks
1.39 9.85 - 137 mph
Re: MILIDON SINGLE OIL LINE [Re: Ari440] #1160419
01/18/12 11:52 PM
01/18/12 11:52 PM
ky
68roadrunner Offline
ky
that should work, just looks kind of wild, stuck out there like that. but nobody is going to look at it anyway.
cant really see one of my lines but it humps up in the middle.
Re: MILIDON SINGLE OIL LINE [Re: Ari440] #1160420
01/19/12 05:08 PM
01/19/12 05:08 PM
If it is losing prime when it sits it has a problem in the supply side of the system that is allowing it to lose the prime, its sucking air instead of oil on start up Air is way thinner than oil so the oil pump will suck the easest fluid it can I have fought that demon several times, it can be fixed My 527 motor has sat a long time(4+ months) between dyno tests, it primes immeadeatly(SP?) every time I prime it before going to the dyno BTW, it is a dual line system with the Milidon adapter spacer for the second line, another place for it to suck air
Re: MILIDON SINGLE OIL LINE [Re: 68roadrunner] #1160421
01/19/12 05:13 PM
01/19/12 05:13 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
If your using a stock k-member, you might run into some clearance issues. Kinda hard to tell from the pics. Might consider running the hose straight up from the pan and then loop into the back side of the pump. There might be enough hose to do that without using the 180 degree hose end. Just a thought.. Good Luck!
Re: MILIDON SINGLE OIL LINE [Re: Gearhead383] #1160422
01/19/12 09:59 PM
01/19/12 09:59 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Here is mine. stock k member with ears.
Re: MILIDON SINGLE OIL LINE [Re: B1MAXX] #1160423
01/19/12 11:43 PM
01/19/12 11:43 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I ran mine like this for several years, and never once had a priming problem at start up. Instant oil pressure, no matter how long it sat.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MILIDON SINGLE OIL LINE [Re: DusterDave] #1160424
01/19/12 11:55 PM
01/19/12 11:55 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
this is how I did mine first
not sure if the loop around the oilpump is restricting oil the way I have it now
anyway I ordered a new indy oilpump for it
1.39 9.85 - 137 mph
Re: MILIDON SINGLE OIL LINE [Re: Ari440] #1160425
01/20/12 01:03 AM
01/20/12 01:03 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Here's mine. It's time for me to upgrade my junk too. Tell me what made you go Indy. And are u changing pans too? I need a new one lol
Re: MILIDON SINGLE OIL LINE [Re: FastmOp] #1160426
01/20/12 01:42 AM
01/20/12 01:42 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my junk
Re: MILIDON SINGLE OIL LINE [Re: FastmOp] #1160427
01/20/12 02:05 AM
01/20/12 02:05 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
lost oil presure 20 pounds took the motor apart and spun number 2 main bearing
the milidon cover is in bad shape bearing material did damage to it
relief valve is stuck , mabey I shouldnt have done the oiline that way , dont know for sure what / why it happened
I went with the indy cover instead of the milidon ,I trust the indy cover
I do have a charlies 10 quart oilpan that I cut up and made it 7 inches deep instead of 8 inhes that it is
its at the machine shop now damaged it backing the car in the garage
and I hit the curb
1.39 9.85 - 137 mph
