Re: nice forum rebuild time?
[Re: cudamank]
#1159103
01/17/12 03:18 PM
01/17/12 03:18 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
If you aren't going to see any track time, save your money. No need for fancy stuff on the street. Just do a good and proper rebuild.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: astjp2]
#1159104
01/17/12 05:13 PM
01/17/12 05:13 PM
Posts: 1,216 Fresno, CA
cudamank
Fresno, CA
Need more info: sway bar sizes and brands, ball joint brands, what your wheel alignment is, etc.
Right now the car is currently stock, or to say that when rebuilt 20 years ago, I used all Moog parts. It retains its factory front sway bar, and did not come with the rear sway bar. I do want to add a rear sway bar. It currently has new XHD rear leaf springs and adjustable drag shocks.
[Re: amxautox]
#1159105
01/18/12 09:09 PM
01/18/12 09:09 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Exactly! Very seriously. No loose joints or bearings and good alignment and you're set.
With adding a rear sway bar, that's going to increase the rear roll rate. Unless you measure the XHD spring rate, free hight and installed hieght, its an big unknown. So to be on the safe side, use a very soft rear sway bar and/or increase the front roll rate.
You can also make almost everything better by moving the battery to the trunk. There are downsides but not in terms of handling.
Then just some other basics. Change the brake fluid if its old, adjust the rear brakes, spend the money for tires intended for your primary goal(s).
edit: Shocks are important. If you're going to continue taking it to the track, then keep them. If not, maybe look at some others especially if you're talking about 90/10 in the front now.
