WHICH OIL THRU LIFTERS FOR HEMI
#1158213
01/15/12 10:15 PM
01/15/12 10:15 PM
Posts: 1,505 TN
SCATPACK 1
TN
World iron Hemi block. Which lifter for pushrod oiling will work in this block
Old Geezer Racing
Re: WHICH OIL THRU LIFTERS FOR HEMI
[Re: SCATPACK 1]
#1158215
01/15/12 11:39 PM
01/15/12 11:39 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Also Comp Elites I think the part # is 98829-16.
[Re: astjp2]
#1158216
01/16/12 02:46 PM
01/16/12 02:46 PM
Posts: 1,505 TN
SCATPACK 1
TN
Tim will your pushrods work with Indy Rockers and Stage 5 stands. Going on a set of Indy HIPO heads Not sure how tal they are compared to stock heads and rockers stuff. What is the length on your set of pushrods for the intake and exhaust. I assume they are oil thru. thanks Jerry
Old Geezer Racing
[Re: astjp2]
#1158219
01/18/12 10:41 AM
01/18/12 10:41 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Depending on valve spring pressures,as said the Comp Elite are in the top of the list.When I purchased mine,there were no elites.I used the comp 848's with oil to the rollers and p/r oil able.I also reduced spring pressures from 750+ ovrt the nose to 600ish.I did not have good luck with the Comp 829's,REDZONES would not fit for over $700,ended up with the Comp 848's and sent oil up the exhaust pushrods
[Re: hemi-itis]
#1158220
09/25/13 02:32 PM
09/25/13 02:32 PM
Posts: 36 Alberta, Canada
572hemi
Alberta, Canada
I have comp elite lifters in my 572 hemi, fresh rebuild with all same clearance's as original engine was set up with, orig was flat tappet and the cam was almost dead at 6400 miles so we went solid roller, it is a crane .587 int, .568 exh , duration @ .050 is 254 int, 262 exh, springs are 155 on the seat, 410 open. Problem now is I lose a lot of oil pressure after the engine heats up, have a Titan oil pump, 85 PSI cold 1500 RPM with 20-50 Z-Alt and about 18 PSI at 1000 RPM hot, 38 PSI @ 2500 rpm on the highway, seems like the lifters have to be the culprit as we did not have this big oil pressure loss issue before. It might be OK but I am bugged by it, have about 2500 miles on it now since changing and seems like there is lots of info out there about solid rollers failing in a street engine application or should I say in 2500 miles. I already have tons of money in this engine and do not want to hurt it again. Any advice would be greatly appreciated, have explored lots of option from Jesel to comp 829 to crower severe duty, Isky Ez-Roll etc
1967 GTX 572 HEMI 735 HP, 717 FT Lb T, , A-855 5 Speed, Dana 60 4:30 Gears, 30" Rear Tires
[Re: Sammy]
#1158222
09/25/13 05:15 PM
09/25/13 05:15 PM
572hemi
Alberta, Canada
Thanks for the info, which Crowers are you using?. I also should have mentioned I want to drive this car a lot so am hoping someone has a story of many miles of only adjusting lash
[Re: Performance Only]
#1158225
09/25/13 08:33 PM
09/25/13 08:33 PM
572hemi
Alberta, Canada
That's what my engine builder told me!!!!
[Re: HEMIFRED]
#1158227
09/26/13 12:21 PM
09/26/13 12:21 PM
Posts: 2,657 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Forgive me for having to ask but why would somebody run oil thru lifters/pushrods with conventional rockers? I understand if you have Jesels. Just wondering. Thanks.
2011 Drag Pak Challenger
#1158228
09/26/13 12:34 PM
09/26/13 12:34 PM
572hemi
Alberta, Canada
I checked the cam card from crane and they called for 200 closed, 455 open so that is what he would have used or close, this engine is not revy, HP is all done at 5774 RPM, 732 HP, torgue is 717 at 4757 rpm, has a indy single plane with 950 holly.
