5.9 1993-2002 question #1156731
01/14/12 03:05 AM
01/14/12 03:05 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
the 2 things i know about them is different heads and roller cam and lifters other than they are the same as the old LA small blocks?
1,, being cheap should be able to find a running engine
2,, cam swap to like a 509 and new valve springs
3,, using single plane M1 intake and holley 650
4,, backed buy a 11 in converter 727 rev body (may switch to 904) with a 4.30 gear 28 tall tire all in a 3400 lbs car
5,, looking for mid 13`s in the middle of summer or am i
Re: 5.9 1993-2002 question [Re: theraif] #1156732
01/14/12 03:37 AM
01/14/12 03:37 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You could do that but it would be a crap combo. forget the Mp .509 cam with an 11" converter(yes,I've tried it) ,a smaller Ultradyne hyd cam will run circles around it,a 9.5" PTC 3600 converter and you'll run low 12's or better and you could even run3.55/ 3.91 gears if you plan on driving it on the highway.I swapped a 360 magnum junkyard engine into a 1st gen Dakota(3560lbs?) many years ago,it runs 12.20's with 3.73 gears,PTC street converter and much smaller than the MP .509 cam. I am doing a cam swap on it and expect to pick up HP and get it well into the 11's and mid 10's on a small shot of n2o. For a combo like yours a 904 would be the best choice.
Re: 5.9 1993-2002 question [Re: goldmember] #1156733
01/14/12 04:36 AM
01/14/12 04:36 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
i would love to use a 9.5 converter but the main driver likes the combo we had witch was 2.00-210 60ft with a 13.30`s et @110 mph
the 509 was just off the to of my head lol
Re: 5.9 1993-2002 question [Re: theraif] #1156734
01/14/12 04:47 AM
01/14/12 04:47 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Some like em soft. I had a similar build come to me a couple of years ago. Swapped the .509 for a real cam and the owner lost control and nearly destroyed a very nice A body while testing the new combo. He needed some time to get used to what a good combo was about.He still had an 11" converter,but a real converter would have been a bigger challenge to make hook.
Re: 5.9 1993-2002 question [Re: theraif] #1156735
01/15/12 04:49 PM
01/15/12 04:49 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
If you're just looking for mid 13's leave the longblock alone, run a air gap intake with a 700-750 carb and some 1 5/8" headers, one of my friends ran that in his scamp a few years ago, 13.60's first time out in the summer with no tuning, he had stock leafs/shocks etc and a 235 drag radial.
Re: 5.9 1993-2002 question [Re: MoparJoe] #1156736
01/15/12 08:26 PM
01/15/12 08:26 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
This is true.The Dakota ran mid 13's when the longblock was stock.
Re: 5.9 1993-2002 question [Re: theraif] #1156737
01/15/12 11:17 PM
01/15/12 11:17 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
I have a 5.9 out of a 2000 durango, has the mopar perf carb intake, the ports have been gasket matched, the bowels cleaned up, the cam out of a 380 horse crate engine, a 650 DP carb and a set of 1 3/4 headers, a really tight production torque converter, and 3.90 gears in a 3600lb ebody that goes 12.80 in 100 degree heat
Re: 5.9 1993-2002 question [Re: cagebob1] #1156738
01/16/12 12:34 AM
01/16/12 12:34 AM
georgia
intenseneon Offline
intenseneon  Offline
georgia
i run a magnum 360 with a hughes 520 lift 220 dur cam. hughes 2k converter mp single plane 3.23 gear, 904 tranny, the car goes 12.80's in a 3200lb duster.
69 Dart
Re: 5.9 1993-2002 question [Re: intenseneon] #1156739
01/16/12 08:29 AM
01/16/12 08:29 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
thanks for info
Re: 5.9 1993-2002 question [Re: theraif] #1156740
01/16/12 12:04 PM
01/16/12 12:04 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
get some hughes #1110 springs and retainers, reuse the stock roller lifters, and get the stock cam reground by Bullet Cams, to something with about 212-216 @.050 duration and .315-.330 lobe lift (I'd go with their HR270/330 lobe) for both intake and exhaust
magnum air gap, 1 5/8" headers, and a 650-750cfm carb and you should be in the high 12's no problem. probably can get by with less gear...
2017 Grand Cherokee Overland
