mufflers #1154195
01/10/12 09:29 PM
01/10/12 09:29 PM
florida dade
cesar perez Offline OP
florida dade
looking for some mufflers that are very quiet but fast
Re: mufflers [Re: cesar perez] #1154196
01/10/12 09:34 PM
01/10/12 09:34 PM
Freeport, Pa
W
whiskeyrunner Offline
W
Freeport, Pa
i run magnaflows...3 inch straight through. couldnt be happier
Re: mufflers [Re: cesar perez] #1154197
01/10/12 09:39 PM
01/10/12 09:39 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Turbo
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: mufflers [Re: cesar perez] #1154198
01/10/12 09:49 PM
01/10/12 09:49 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Dynomax 3" welded ultraflows
Re: mufflers [Re: Dodgem] #1154199
01/10/12 10:33 PM
01/10/12 10:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
with this guy!
Re: mufflers [Re: whiskeyrunner] #1154200
01/10/12 11:04 PM
01/10/12 11:04 PM
I run the 3 inch inlet and outlets, 14x7 ovals Magnaflows that have the side entrance with the center exit. I have them mounted at the rear bumper, nice and quiet until you get the loud pedal opened up more than 1/3 of the way to wide open
Re: mufflers [Re: Cab_Burge] #1154201
01/10/12 11:09 PM
01/10/12 11:09 PM
Texas, USA
68cuda2003 Offline
68cuda2003  Offline
Texas, USA
check spintech. they have many different configurations and they sound fantastic. good luck. Ken
Re: mufflers [Re: whiskeyrunner] #1154202
01/10/12 11:36 PM
01/10/12 11:36 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Same here!
Re: mufflers [Re: cesar perez] #1154203
01/10/12 11:40 PM
01/10/12 11:40 PM
Az
Crizila Offline
Crizila  Offline
Az
Oxymoron!
Fastest 300
Re: mufflers [Re: Crizila] #1154204
01/11/12 12:38 AM
01/11/12 12:38 AM
Central NC
gch Offline
gch  Offline
Central NC
Dynomax large case super turbo or accurate ltd hi po muffler.
Re: mufflers [Re: gch] #1154205
01/11/12 12:46 AM
01/11/12 12:46 AM
florida dade
florida dade
at the current time i run 4 inch magnaflow i just hate the noise i waNT IT TO BE QUIET AND FLY
Re: mufflers [Re: cesar perez] #1154206
01/11/12 12:55 AM
01/11/12 12:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm happy with the pair of Hooker Aerochambers
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: mufflers [Re: cesar perez] #1154207
01/11/12 01:31 AM
01/11/12 01:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I recommend Borla XR1 12" body. They arent cheap but they are unbelievably wicked sounding and sound like a kitten at idle.
Mopar to the bone!!!
Re: mufflers [Re: 72Swinger] #1154208
01/11/12 01:43 AM
01/11/12 01:43 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
I have always liked Borlas, well that is after Scott Brown no longer made mufflers. We have his stuff on our Camaro(sorry)and it is quiet as a church mouse and still runs bottom 10's. Anyway the key is to put the muffler as far back as possible in the car. By the rear bumper if possible as the last part of the exhaust before the tip.
Re: mufflers [Re: Al_Alguire] #1154209
01/11/12 01:13 PM
01/11/12 01:13 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I think the D-max Ultraflows sound great but are not gonna qualify as "Very Quiet" On a big motor car with 11.5:1 and a big cam they don't knock the DB's down very much...If you look at an UF it's essentially a perforated resonator tube in a muffler case.
D-max Hemi Turbo's really are reasonably quiet but arguably more restrictive than Ultraflows on a big motor at high RPM. But Real world 95% of the time... not very much performance difference on a properly designed system with collector extentions and an X pipe. I run them on a 12:1 ~720hp 517 and they're quiet "enough" ....barely. I had considered Ultraflows for this motor but with the cam and overlap I might as well run open headers as far as knocking down the Decibels. On my old 600 hp 508 they would have been fine though.
Dynomax has a muffler that is a hybrid of a short Ultraflow with a spring loaded Flapper valve, that may be worth looking at.
Hooker Aero's sound really good and are low restriction...based on your request that might be one worth looking at.
Edelbrock Stainless mufflers that had a split flow -<>- (Like an Ultraflow but with a double Y in the case) are fairly quiet and very low restriction as well. I think they copied the design from the SLP Firehawk. Not sure if they still make them anymore though, but they're a nice alternative.
In many states they're is an 80 or 85 DB max at 100 feet before they can cite you for noise.
WIZE
In Car:
Re: mufflers [Re: cesar perez] #1154210
01/11/12 01:46 PM
01/11/12 01:46 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Are you staying w/ a 4" system? If so, that's going to really limit your choices for mufflers. Need to know this so we can recommend you something. Some that have been mentioned here are not available in 4".
CHIP
'06 GMC 2500HD LBZ Duramax
Re: mufflers [Re: an8sec70cuda] #1154211
01/11/12 03:49 PM
01/11/12 03:49 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi,
are there any round type that you could slip on a collector to quiet it down some? without doing an actual exh system 3 1/2in. collector. this is for a race car.
Russ
Re: mufflers [Re: old_racer] #1154212
01/11/12 04:24 PM
01/11/12 04:24 PM
Hi,
Russ
You could use a pair of Dynomax Bullets or Flowmaster Outlaws. They don't look like they'd do much, but they're better than open headers. Not sure if they'd slip over your collector...might have to flare them out a little.
CHIP
Re: mufflers [Re: Dodgem] #1154213
01/11/12 04:33 PM
01/11/12 04:33 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
That's what I run. FWIW, on my car, it ran 10.68 open header'd, and 10.78 with my full exhaust. My exhaust is kind of heavy @ 70 lbs. so most of that was weight.
-Kenny
Re: mufflers [Re: an8sec70cuda] #1154214
01/11/12 04:42 PM
01/11/12 04:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Did anyone read the OP?? He said "very quiet". Maybe he should have given a decibel reading he wanted to stay under, cause none of the muffs listed fall in the very quiet catagory IMO. Straight throughs of any kind shouldn't even be a consideration - unless they are mounted on a sewing machine .
Fastest 300
