Re: mufflers
[Re: cesar perez]
#1154207
01/11/12 01:31 AM
01/11/12 01:31 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I recommend Borla XR1 12" body. They arent cheap but they are unbelievably wicked sounding and sound like a kitten at idle.
Mopar to the bone!!!
Re: mufflers
[Re: 72Swinger]
#1154208
01/11/12 01:43 AM
01/11/12 01:43 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I have always liked Borlas, well that is after Scott Brown no longer made mufflers. We have his stuff on our Camaro(sorry)and it is quiet as a church mouse and still runs bottom 10's. Anyway the key is to put the muffler as far back as possible in the car. By the rear bumper if possible as the last part of the exhaust before the tip.
Re: mufflers
[Re: Al_Alguire]
#1154209
01/11/12 01:13 PM
01/11/12 01:13 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
I think the D-max Ultraflows sound great but are not gonna qualify as "Very Quiet" On a big motor car with 11.5:1 and a big cam they don't knock the DB's down very much...If you look at an UF it's essentially a perforated resonator tube in a muffler case. D-max Hemi Turbo's really are reasonably quiet but arguably more restrictive than Ultraflows on a big motor at high RPM. But Real world 95% of the time... not very much performance difference on a properly designed system with collector extentions and an X pipe. I run them on a 12:1 ~720hp 517 and they're quiet "enough" ....barely. I had considered Ultraflows for this motor but with the cam and overlap I might as well run open headers as far as knocking down the Decibels. On my old 600 hp 508 they would have been fine though. Dynomax has a muffler that is a hybrid of a short Ultraflow with a spring loaded Flapper valve, that may be worth looking at. Hooker Aero's sound really good and are low restriction...based on your request that might be one worth looking at. Edelbrock Stainless mufflers that had a split flow -<>- (Like an Ultraflow but with a double Y in the case) are fairly quiet and very low restriction as well. I think they copied the design from the SLP Firehawk. Not sure if they still make them anymore though, but they're a nice alternative. In many states they're is an 80 or 85 DB max at 100 feet before they can cite you for noise.
Re: mufflers
[Re: cesar perez]
#1154210
01/11/12 01:46 PM
01/11/12 01:46 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
at the current time i run 4 inch magnaflow i just hate the noise i waNT IT TO BE QUIET AND FLY
Are you staying w/ a 4" system? If so, that's going to really limit your choices for mufflers. Need to know this so we can recommend you something. Some that have been mentioned here are not available in 4".
Re: mufflers
[Re: old_racer]
#1154212
01/11/12 04:24 PM
01/11/12 04:24 PM
an8sec70cuda
Hi, are there any round type that you could slip on a collector to quiet it down some? without doing an actual exh system 3 1/2in. collector. this is for a race car. Russ
You could use a pair of Dynomax Bullets or Flowmaster Outlaws. They don't look like they'd do much, but they're better than open headers. Not sure if they'd slip over your collector...might have to flare them out a little.
Re: mufflers
[Re: Dodgem]
#1154213
01/11/12 04:33 PM
01/11/12 04:33 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Dynomax 3" welded ultraflows
That's what I run. FWIW, on my car, it ran 10.68 open header'd, and 10.78 with my full exhaust. My exhaust is kind of heavy @ 70 lbs. so most of that was weight.
-Kenny
Re: mufflers
[Re: an8sec70cuda]
#1154214
01/11/12 04:42 PM
01/11/12 04:42 PM
Posts: 7,506 Az
Crizila
Az
Did anyone read the OP?? He said "very quiet". Maybe he should have given a decibel reading he wanted to stay under, cause none of the muffs listed fall in the very quiet catagory IMO. Straight throughs of any kind shouldn't even be a consideration - unless they are mounted on a sewing machine .
Fastest 300
