'69 master cylinder cover interchange #1153939
01/10/12 11:40 AM
01/10/12 11:40 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Does anyone know if the two hump m/c cylinder cover, drum brake, will fit the after market m/c, which comes with the inverted bathtub cover.
Re: '69 master cylinder cover interchange [Re: demonH1B] #1153940
01/10/12 08:39 PM
01/10/12 08:39 PM
USA
b54406barrel Offline
USA
Probably. When I put the one on my '70- 6bbl car that I got from Napa back in the 70's, it came with a stock cover. Still on there, no leaks.
Re: '69 master cylinder cover interchange [Re: b54406barrel] #1153941
01/10/12 09:11 PM
01/10/12 09:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have both master cylinders and i'm going to say no.
Re: '69 master cylinder cover interchange [Re: demonH1B] #1153942
01/11/12 09:24 AM
01/11/12 09:24 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
In other words, can you take a new unit such as from Napa or somewhere and use the old bolt on cover...in place of the bolt on cover they currently sell that is a one hump, inverted bath tub looking thing? Yes, I have done it with no issues, just make sure your bolt isn't too long so that it bottoms out before the cap is tight.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: '69 master cylinder cover interchange [Re: Kowal] #1153943
01/11/12 11:57 AM
01/11/12 11:57 AM
n/w, PA
demonH1B Offline OP
demonH1B  Offline OP
n/w, PA
Thanks for the replies.
Re: '69 master cylinder cover interchange [Re: demonH1B] #1153944
01/11/12 06:31 PM
01/11/12 06:31 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the master cylinder on the right came of my 69 r/t; the left is the common aftermarket. think the tops will interchange?
Re: '69 master cylinder cover interchange [Re: lewtot184] #1153945
01/11/12 06:46 PM
01/11/12 06:46 PM
USA
USA
I've never had a master for a drum brake mopar with a bail, always been a bolt on. And I'm pretty sure I've seen the 'bathtub' one he's describing & it's a bolt on. The bail MC were for disc cars originally, I think. Maybe some drum replacements have the bail, now?
Re: '69 master cylinder cover interchange [Re: lewtot184] #1153946
01/12/12 08:55 AM
01/12/12 08:55 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Ok, obviously these two won't swap. This isn't the two I was talking about.
Re: '69 master cylinder cover interchange [Re: lewtot184] #1153947
01/12/12 10:17 AM
01/12/12 10:17 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
not a chance
Re: '69 master cylinder cover interchange [Re: gtx6970] #1153948
01/12/12 10:28 AM
01/12/12 10:28 AM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
If I am not mistaken? The one on the left is for power drum brakes and the right non power drums.
But I have been wrong before!
Ed
Re: '69 master cylinder cover interchange [Re: XXHEMI] #1153949
01/12/12 10:49 AM
01/12/12 10:49 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Ed
i don't think there is any difference in power or manual master cylinders using drum brakes. disc brakes had a different master cylinder.
Re: '69 master cylinder cover interchange [Re: XXHEMI] #1153950
01/12/12 11:08 AM
01/12/12 11:08 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ed
Ed, the one on the left is 1971 and newer drum brakes - regardless if power or manual
The one on the right is 1967 thru 1970 drum brakes - regardless if manual or power
Although they will interchange and function as an assembly with no problems,,, the parts of each are unique to each other and are not interchangable
Re: '69 master cylinder cover interchange [Re: demonH1B] #1153951
01/12/12 05:11 PM
01/12/12 05:11 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Does anyone know if the two hump m/c cylinder cover, drum brake, will fit the after market m/c, which comes with the inverted bathtub cover. [/quote
Yes,if you mean the cover with the raised top with a center bolt.
Re: '69 master cylinder cover interchange [Re: pushbutton] #1153952
01/12/12 05:15 PM
01/12/12 05:15 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Re: '69 master cylinder cover interchange [Re: pushbutton] #1153953
01/12/12 05:17 PM
01/12/12 05:17 PM
PA
BTTG Offline
BTTG  Offline
PA
so this cap
http://www.beaparts.com/showlargeimage.aspx?id=236-MCC&filetype=large%20image
fits this master cylinder (attached), which from the discussion is a non-original replacement or at least now has a non original cover (car is power drums)
Re: '69 master cylinder cover interchange [Re: BTTG] #1153954
01/12/12 06:06 PM
01/12/12 06:06 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
so this cap
this picture helps me understand the OP's question. they should interchange.
Re: '69 master cylinder cover interchange [Re: BTTG] #1153955
01/12/12 06:11 PM
01/12/12 06:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I have a couple original mopar drum brake master cylinders and one or 2 of the aftermkt masters with the single hump lid.
Over the weekend , I'll pull the lids off one of each and see if they interchange with no issues.
Re: '69 master cylinder cover interchange [Re: gtx6970] #1153956
01/13/12 02:11 PM
01/13/12 02:11 PM
USA
USA
Re: '69 master cylinder cover interchange [Re: gtx6970] #1153957
01/13/12 02:19 PM
01/13/12 02:19 PM
PA
BTTG Offline
BTTG  Offline
PA
Without falling into possibly being tricked by the cap how can you tell if the master cylinder is original (original type) for a 69?
stampings on the MC body?
Re: '69 master cylinder cover interchange [Re: BTTG] #1153958
01/13/12 02:29 PM
01/13/12 02:29 PM
USA
USA
Yes, stampings along the bottom & front. The new replacement I bought from Napa in '78 had that extra little bump right on the front & originals don't have that so it's easy to spot. It did come with that cap though which looks just like an original, even down to the bolt head having that funny little 'H'.
