Need help selecting speedo gear for OD 4-speed #1153424
01/09/12 09:51 AM
01/09/12 09:51 AM
Stuart, FL
Grassosgarage Offline OP
Stuart, FL
Ok, I transplanted a 833 OD 4-speed into my '65 Valiant with a 3.21 gear and 225 70 14 tires. The speedo now reads much faster than car is actually going. I don't expect precision accuracy from a '65 Valiant speedo, but anybody have an idea which # of teeth on the gear wil get me close? I don't know if the OD is a factor, or just the change in rear gear.
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: Need help selecting speedo gear for OD 4-speed [Re: Grassosgarage] #1153425
01/09/12 10:17 AM
01/09/12 10:17 AM
scratchnfotraction Offline
there is a chart in the arcives IIRC
i think you need to check whats in there and most liky need a larger gear to slow the speedo down
I been grabing the gears out of the JY and have a few now,24-27-35-40 ect.
Re: Need help selecting speedo gear for OD 4-speed [Re: Grassosgarage] #1153426
01/09/12 12:23 PM
01/09/12 12:23 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
2 Demons...no, not my kids!
Re: Need help selecting speedo gear for OD 4-speed [Re: 4speeds4me] #1153427
01/21/12 10:52 PM
01/21/12 10:52 PM
Stuart, FL
Stuart, FL
ok, this chart is great but it assumes 4th gear is 1:1. Do these ratios apply to an OD trans?
Re: Need help selecting speedo gear for OD 4-speed [Re: Grassosgarage] #1153428
01/21/12 11:06 PM
01/21/12 11:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Speedo is on the output shaft. Gears have no affect.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Need help selecting speedo gear for OD 4-speed [Re: moparmarks] #1153429
01/21/12 11:08 PM
01/21/12 11:08 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Re: Need help selecting speedo gear for OD 4-speed [Re: Grassosgarage] #1153430
01/22/12 12:27 PM
01/22/12 12:27 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
real easy way to get in the ballpark... assumes typical 26-27" tires:
Take axle ratio. Drop last digit. That's # of teeth needed on speedo pinion!
Rick
Re: Need help selecting speedo gear for OD 4-speed [Re: Rick_Ehrenberg] #1153431
01/22/12 03:33 PM
01/22/12 03:33 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
This chart / guide worked well for me.
http://www.mymopar.com/index.php?pid=112
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
