Help! ID Torqe Converter #1152768
01/08/12 02:57 AM
01/08/12 02:57 AM
Iowa
E
eaglesguy1981j Offline OP
E
Iowa
I have a Torque converter that I picked up. Guy I bought it from said it stalled about 3300 behind his Small block 727 trans.
I cant find any numbers on this wondered if yall might be able to help?
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152769
01/08/12 02:58 AM
01/08/12 02:58 AM
Iowa
E
E
Iowa
another photo
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152770
01/08/12 02:59 AM
01/08/12 02:59 AM
Iowa
E
E
Iowa
These are the only numbers I could find.
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152771
01/08/12 01:30 PM
01/08/12 01:30 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
saw a blog on a-bodies.com and a guys describes his ,same numbers as yours and says its most likly a stock hp or t/a 340 piece thats about 2300 stall.just go to google and type in rg13oh.
Re: Help! ID Torqe Converter [Re: moparsquid] #1152772
01/08/12 03:33 PM
01/08/12 03:33 PM
Iowa
E
E
Iowa
the numbers when you google them just brings up the info on the ring gear which leads me to believe its just for the ring gear. Also if you look at the engine side it looks nothing like a stock converter.
Re: Help! ID Torqe Converter [Re: moparsquid] #1152773
01/08/12 05:24 PM
01/08/12 05:24 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
go into a-bodies .com and look for the blog on it a guy decribes that converter.good luck...
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152774
01/08/12 05:24 PM
01/08/12 05:24 PM
Iowa
E
E
Iowa
Ive tried googling the first part of the number and I only get info on the ring gear. I'm not sure how to google the rest of the numbers. and I know the RG130 is for Ring Gear 130 tooth. I don't believe its stock either it is a 10" converter. When I bought it the guy said he thought it was a Coan. But I have called them and they have never done there converters in orange or red shade. And it doesnt appear to be repainted. I bought this when I first got into cars a few years ago and the seller didnt offer up much info. Getting closer on my build and this remains a question mark.
Re: Help! ID Torqe Converter [Re: moparsquid] #1152775
01/08/12 05:26 PM
01/08/12 05:26 PM
Iowa
E
E
Iowa
Ive been on a bodies. Ive seen the post from Billytuffnuts. Again the numbers on the ring gear are for the ring gear part number. http://www.sonnax.com/product-lines/torque-converter/parts/129 appears to be a sonnax part number.
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152776
01/08/12 05:32 PM
01/08/12 05:32 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I had one like this before ,it was called a j converter for super stock racing, i think direct conection put it out had a high stall but dont recall the speed.
Re: Help! ID Torqe Converter [Re: moparsquid] #1152777
01/08/12 05:59 PM
01/08/12 05:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, look at the first pic; the front shell has 6 drive lug flats which are common to the small 9.5-10" GM converters (Geo)...definitely aftermarket.
Re: Help! ID Torqe Converter [Re: John_Kunkel] #1152778
01/08/12 06:24 PM
01/08/12 06:24 PM
Iowa
E
E
Iowa
What are you counting? I count 8? Talking about the flats on the front/engine side right?
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152779
01/08/12 08:52 PM
01/08/12 08:52 PM
Iowa
E
E
Iowa
Yeah i knew it was a long shot. Ive seen a TA and a Stock 340 converter and that looks nothing like either of them.
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152780
01/09/12 05:49 AM
01/09/12 05:49 AM
Iowa
E
E
Iowa
weekday crowd anyone know this?
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152781
01/09/12 07:55 AM
01/09/12 07:55 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Hughs converters are red
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152782
01/09/12 08:27 PM
01/09/12 08:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OOPS!! Going blind. The 8 flats makes it a 10" Ford Capri or such, still definitely not Mopar.
Re: Help! ID Torqe Converter [Re: John_Kunkel] #1152783
01/09/12 08:31 PM
01/09/12 08:31 PM
Iowa
E
E
Iowa
im sure its mopar. I bought the thing from a member on here. It is a mopar ring gear and the splines are the same as my trans.
Re: Help! ID Torqe Converter [Re: ThermoQuad] #1152784
01/09/12 08:33 PM
01/09/12 08:33 PM
Iowa
E
E
Iowa
I dont believe its a hughes. mine looks nothing like that one in the photos. the one in your photo is smooth on the transmissions side
Re: Help! ID Torqe Converter [Re: eaglesguy1981j] #1152785
01/09/12 08:59 PM
01/09/12 08:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure, it's FOR a Mopar but it's not factory Mopar. The shells that are used for small Mopar converters are pirated form other makes.
Re: Help! ID Torqe Converter [Re: John_Kunkel] #1152786
01/09/12 10:08 PM
01/09/12 10:08 PM
Iowa
E
E
Iowa
Yeah I get what your saying. Even if it doesnt stall at the 3200 range like he said it did behind his small block. But its going behind a 440 so that should boost stall. just be nice to know what I got.
