a body front tire size #1152173
01/07/12 02:13 PM
01/07/12 02:13 PM
southwest pa
bodyworks racing Offline OP
southwest pa
what size tires are you running on your street strip a bodys this is a big block we are currently setting up the cap tubular k frame with a front mount rack and pinion have 195 x65 15 and are having clearance issues at the frot edge of the fenders thoughts and suggestions welcome
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: a body front tire size [Re: bodyworks racing] #1152174
01/07/12 04:04 PM
01/07/12 04:04 PM
Figure out what front size and width tires and rims you want to run and then trim the fenders as needed I could run 26x15 inch tall M/T front runners on four inch wide rim (1 7/8 rear offset)with no problems on my 1971 Duster with stock,uncut front fenders. I bought a set of Moroso 7.10x15(27 1/4 hieght) and mounted them on a set of Centerline 4x15 rims with 2 1/8 rear offset and had to trim the front edges and remove two of the inner fender bolts bolts that hold the inner splash shields in the fenders Your call BTW, the front ride hieght plays a big factor on which ones fits and which ones don't
Re: a body front tire size [Re: bodyworks racing] #1152175
01/07/12 05:11 PM
01/07/12 05:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i have 26x7.5x15 on my demon, sb with altercation frt end. don't know back spacing. that's the tallest that will fit. seeya.
Re: a body front tire size [Re: rickraw] #1152176
01/07/12 05:24 PM
01/07/12 05:24 PM
Super Scamp Offline
Super Scamp  Offline
I have 26x4x15 on the Scamp with 1.75 BS with WW brakes. Billetspecialties rims
Just One Man's Opinion Mopar Mafia Racing
Re: a body front tire size [Re: Super Scamp] #1152177
01/07/12 05:31 PM
01/07/12 05:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
27 tall tires ... 215 75 15 ... prostar rims
RB indy head with proparts headers
1.39 9.85 - 137 mph
Re: a body front tire size [Re: Ari440] #1152178
01/07/12 07:00 PM
01/07/12 07:00 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I recently went through this and every car/wheel combo will be different. I have 15x4 Welds with 2.25 back spacing and a 205/75R15(27.1in. tall) hit on the front edge of the fender by just a bit. A 205/70R15(26.3in. tall) fits fine. My car is fairly low in the front with only a few inches between the under-steering headers and the ground. I have the 70's on there for now but my go back to the taller tires when I get the ride height sorted out. First pic is the 26.3's second is 27.1's
Re: a body front tire size [Re: j.mcconnell] #1152179
01/07/12 07:37 PM
01/07/12 07:37 PM
southwest pa
southwest pa
thanks for the replys today we adjusted the dynamic strut rods to push the lower control arms back.we ended up with 3.5 degrees of pos caster this helped the clearance but its still close. unfortunatly we cant cut the fenders the body work is already done.the rim are billet specialties 15 x 4 buy 1.75 back space. we would like to have gone deeper with the backspace but the fabrication done to the spindle buy cap to make it front mount turns the tie rod mount towards the rim like an ackerman style mount. i am a little vauge on why ? would have thought it would have stayed in line with the ball joint!going to post pics if i can figure out how .somewhat computer challenged
