Re: What suspension mods are in YOUR B body?
[Re: Grizzly]
#1151287
01/11/12 01:37 PM
01/11/12 01:37 PM
Posts: 5,406 Pikes Peak Country
TC@HP2
Pikes Peak Country
Ok, no offense taken. It was explained to me a different way.
Thanks.
No problem. I have seen this line of reasoning often, so while incorrect, it isn't that unusual.
Remember that sway bars are simply transverse torsion bars. IE they add spring rate. Too much spring rate can overpower the grip a tire generates. So either add grip to the tire, which tough to do, or soften the dpring rates, which is somewhat easier do.
This is the biggest drawback to owning a handling mopar. There are limited t-bar rates available to fine tune with compared to coil springs which are available with only 50# differences from 200 to 1500 pounds.
[Re: TC@HP2]
#1151288
01/11/12 07:33 PM
01/11/12 07:33 PM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Here's what I have and it handled great on the track and autocross. I don't know the manufacturer of the rear springs, but they are very stiff and I don't use a sway bar in rear, and didn't feel it needed one on the track. I have the below radiator brace from XV, didn't go further due to paint. Hotchkis UCA's strut rods and steering links. Get the biggest T bars you can get and hotchkis biggest front swaybar. Welded K member, FF stage 3 and fast ratio Pitman and Idler. Hotchkis bilsteins. I would also suggest Nitto NT05's the next time you get tires. I like the way hotchkis does the frame connectors on stock mounted springs. My suggestion is a TVS followed by a big brake kit up front. If you do rear disks and auto cross, you need to learn about pad knock back. A floating caliper is really needed back there. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: astjp2]
#1151290
01/11/12 09:34 PM
01/11/12 09:34 PM
Posts: 23,410 Here
jcc
Here
I'm so glad this is in the HP suspension handling section. Reg Front brake choice, what's your application, budget, "flash factor" requirements, car weight, tires (they are what really stops a car) and are you sure a 13.59" rotor will fit a 17" wheel? Anyway, having a heavy too large for the application rotor setup, will actually slow a car down, for little extra margin in braking, and IMO, just hang a sign over your head that your are a mopar peacock
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: ThermoQuad]
#1151292
01/12/12 12:41 PM
01/12/12 12:41 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Do not use the edelbrock shocks. Do not.
Bilsteins or adjustable QA1's-best choice as every car is different.
Here is a well mannered high speed big fat B body with lots of welding and few "mods"
The welded k frame is a key piece, do not pass go, do not buy expensive parts or put in the hotchkiss products unless you weld the k frame and box the steering mount.
Do not "over tire" the car. Most cars with big tires/wheels have wayyy tooo much tire under the car. Think 26-27 inches tall 10 inch wide tire.
That's about it for now
Will some one please tell Moparts Tom we deserve our own handling section.
[Re: ThermoQuad]
#1151293
01/12/12 01:01 PM
01/12/12 01:01 PM
Posts: 23,410 Here
jcc
Here
I have no real world on track experience to dispute or confirm the above, but since I have seen many chopped/cutout/sectioned K members on moparts for clearance/oil pan issues, and none of them IMO retained the full strength/rigidity of an OEM K member, dose that mean they all went backwards in performance, accepting most were 1/4 mile apps?
And "over tire" is specific for application, since I can't imagine in dry conditions on track that except for limited hp, any tire would be oversize, maybe not cost effective, but never to big. Brakes are another matter. We'll discuss that on the brake thread in HP suspension section
[Re: jcc]
#1151294
01/12/12 01:37 PM
01/12/12 01:37 PM
Posts: 805 San Francisco Bay Area
MrAngry
Tom - the Edelbrock shocks are fine for the street, but I do agree - for the track you need step it up. I've got a set of Ridetech single adjustables that I'm going to install for track duty so I'll post up and see how they feel in a few weeks.
Never trust a pretty girl... or a lonely midget.
[Re: MrAngry]
#1151295
01/12/12 02:10 PM
01/12/12 02:10 PM
MrAngry
I just posted that we needed a HANDLING section in general, so chime in if you want to see one!
[Re: MrAngry]
#1151297
01/12/12 02:22 PM
01/12/12 02:22 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
I can give a quick review of the RideTech's.....Mike was witness to how they worked in our car at the OUSCI. Right out of the box they were a beautiful shock. They are built by FOX in conjuction with Ridetech. Installation was fairly straight forward but they do require some creativity. I know they are working on making it completely compatible. On the track, I do not believe you could ask for anything more out of a semi- budget shock. They have 26 positions to adjust but you can settle into a few area for street and track. The adjustments you feel right away. I do have quite a few bolt on parts on my car to help with body roll, but for overall feel of the track, I give them a 10. I know Mike is going to do a write-up on these in the future, so I am sure he will get into this more.
Can I give some advice on brakes- Be careful with the monster brake kits as a street tire (200 rating and above) can only handle so much force before lock-up. I watched countless cars blow up the tires in the speed stop challenge, because unless you are running slicks, they grip is just not there.
Tom Quad- I am bit concerned about some the advice you are giving... Where do these comments come from? You telling people to stay away from the IAS EDDY monotube shock, but advising them to go to a QA1 twin tube shock instead.....not good advice. The bilsteins and QA1 are not even comparable on B-body applications.
As far as not putting too much tire under the car.....seriously! It's about the balance of the car and what is reasonalbe for what you are using it for. It all starts and stops with the rubber.......
Not trying to pick on you Tom, but Mike and I have not a single MOD to your K-Members and we track them all the time.........with Hotchkis, and other companies, stuff bolted to it.
[Re: MrAngry]
#1151300
01/12/12 03:56 PM
01/12/12 03:56 PM
Posts: 181 Washington State
70chall440
Washington State
this aspect of classic Mopar's is the least understood area of all. there is so much mis-information it is crazy. when I was planning my Cuda, I searched all over and talked to many many people about it. The biggest issue is that most people are interested in street manners, however everyone defaults to full on racing advice. That said, there is a lot of correlation between the two, however not all of it transends from one to the other. Next is more personal; it is very hard to articulate what you want as an individual. What is acceptable (or even mandatory) to one person, is compelely unacceptable to another (just look at the opinions on shocks alone). This makes giving or recieving information very difficult.
In my case, I have a Viper and a 10 Challenger to use as "base lines". As you all know, making a 70's era Mopar handle like either of them is an expensive and elusive target. Most people just want thier car to handle, however many people dont remember or even know what these era of cars handled like new and are now comparing them (original or restored) against new cars and cannot help but ask how to make them better.
I went "whole hog" on my Cuda, sub frame connectors, full bracing on the inner fenders, welded K frame, fast ratio steering components, etc. Dont have the car together yet, so I cant tell you how it handles, however based on compnent selection and advice of "experts" (Dick at Firm Feel being one), the car should handle well. However this is intended to be a road race street car, not a new car to be driven 200K miles. I am confident it will be stiff riding (Bilstin up front, 1.14" torsion bars, 1.25" sway bar, strange coil over rear shocks, 4 link, welded LCA, tublar UCA, etc.).
Point here is that we need a handling section to house all of these issues, threads and opinions to allow people to get as much information as possible to make a decision. If possible, it should be divided into street cars, road race, etc. Perhaps something about tires and shocks... I am sure I am asking for too much but I thought I would throw it out there.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
[Re: PHJ426]
#1151303
01/12/12 09:59 PM
01/12/12 09:59 PM
OLD318
70 Coronet/ 318 -SuperBee Lower Control arms with sway bar tabs/ boxed, moog bushings -Stock UCA with MOOG offset bushings +2.5 caster setting -Firm Feel front sway bar package -MP .96 Torsion bars -Steer-N-Gear Stage 1 power steering gearbox - MOOG suspension parts - rubber bushings - MP front & rear shocks (old gas style) -Hemi leaf springs on the back What I have is a HUGE improvement over stock but... IF I had it to do all over again - skip the stock UCA rebuild and offset bushings buy aftermarket UCA like - Hotchkiss etc. - Stage 2 gearbox - 1" or bigger torsion bars - Add rear sway bar pkg.
