Re: Anyone use a remote oil filter? [Re: rebel] #1151216
01/07/12 04:33 PM
01/07/12 04:33 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Hey Rob I have a CV products filter housing and a System1 filter. I like the ability to pull it apart and inspect the filter element.
Steve
Photobucket sucks
Re: Anyone use a remote oil filter? [Re: 68cuda2003] #1151217
01/07/12 04:41 PM
01/07/12 04:41 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Has anyone tried the K&N filters? Just asking????
I have had no problems so far with them .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Anyone use a remote oil filter? [Re: Kam*Kuda] #1151218
01/07/12 08:19 PM
01/07/12 08:19 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Any experience with one of these ?
Can the be used as a primary filter on a wet sump application ?
I have used the dual filter ( Fram PH-8's ) set up in the past , but it was a show and tell piece more than a performance enhancer.
But I got one of these on the cheap and like the notion of a re-usable filter and ease of inspection.
http://cvproducts.com/ProdDet.aspx?PN=CAN25-106
Re: Anyone use a remote oil filter? [Re: dOc …] #1151219
01/08/12 12:18 AM
01/08/12 12:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What happens to an oil filter with a bypass that's rated at 20 GPM when it gets hit with over 20GPM???
After my 1st lifter failure,there was contamination throughout the entire oiling system embedding in all the bearings.That's when I did my homework on oil filters and changed to a non-bypass style filters.The Moroso filters flow 16 GPM each.My second lifter failure resulted in no contamination getting past the oil filters.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Anyone use a remote oil filter? [Re: hemi-itis] #1151220
01/08/12 01:06 AM
01/08/12 01:06 AM
hemi-itis Offline
hemi-itis  Offline
When I went back to Lou Vignogna after the 1st lifter failure to rebuild the hemi,Jimi Vignogna told me to use these in the oil pick up lines
Re: Anyone use a remote oil filter? [Re: hemi-itis] #1151221
01/08/12 09:00 PM
01/08/12 09:00 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I have a Pure Power remote on both cars.
Re: Anyone use a remote oil filter? [Re: jim sciortino] #1151222
01/18/12 08:22 PM
01/18/12 08:22 PM
hemi-itis Offline
hemi-itis  Offline
Jim,could you share your experience with that oul filter,I curious how long you have used it,what is flows and how you clean it
Re: Anyone use a remote oil filter? [Re: hemi-itis] #1151223
01/18/12 08:44 PM
01/18/12 08:44 PM
Trumbull,CT.
Trumbull,CT.
Had it for a couple years on my Cuda'. Works well, so we put one on my Dart too....
When I change the oil, I just unscrew the housing and slip out the filter, wash it in solvent, then soap and hot water, then only with water and blow it dry. It's small and easy to package.
Go to Pure Power's site and check em' out. It has alot of info.
