741 Ring & Pinion
#1150208
01/04/12 07:38 AM
01/04/12 07:38 AM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
I picked up a 741 open chunk with a new 3.23 and wondering if the ring and pinion is the same as on the cone style sure-grip?
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 741 Ring & Pinion
[Re: CUUDAK]
#1150209
01/04/12 08:43 AM
01/04/12 08:43 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
The SG will work in the 741 housing but if the R&P came from a 742 or 489 they wont fit the 741 housing.Rocky
Chrysler Firepower
[Re: CUUDAK]
#1150210
01/04/12 10:39 AM
01/04/12 10:39 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
You Can use the sure grip on the 741 ring and pinion IN tech 741 case as long as you use the side bearings for the sure grip unit.
[Re: MoparforLife]
#1150211
01/04/12 02:58 PM
01/04/12 02:58 PM
CUUDAK
HEMPSTEAD TX
I have three 741 cases and two are 741 cone style Sure-grips. The two Sure-grips are 3.55 and 3.91. I just want to swap the ring & pinion from the 741 that has the open diff into one of the 741 cases with the Sure-grip. Just wanted to make sure the r&p is the same between the open and the SG.
[Re: CUUDAK]
#1150214
01/04/12 08:12 PM
01/04/12 08:12 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
All the 8-3/4 rears have interchangeable SG units (clutch or cone). The gears won't interchange. The 741 is a small diameter straight pinion, 742 is large straight pinion and the 489 is a large tapered pinion that uses a crush collar for preload.
[Re: torkrules]
#1150215
01/04/12 11:50 PM
01/04/12 11:50 PM
CUUDAK
HEMPSTEAD TX
Thanks for all the info folks!! I will just install the 3.23 ring gear on the sure-grip and put it in the open case.
[Re: therocks]
#1150216
01/05/12 12:32 AM
01/05/12 12:32 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
...since THIS GUY has been werkin' on Mopars since the Stone Age .... TAKE his word furr it ..
