Thermoquad needle and seat #1150005
01/03/12 05:01 PM
01/03/12 05:01 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
Does anyone know who sells larger than stock needles and seats. I tried Demon Sizzler but his web site is no longer active.
Raul
Re: Thermoquad needle and seat [Re: Aspen7695] #1150006
01/03/12 05:48 PM
01/03/12 05:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Try these guys www.walkerproducts.com
Re: Thermoquad needle and seat [Re: ScottSmith_Harms] #1150007
01/04/12 02:41 PM
01/04/12 02:41 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i drilled mine out per demonsizzler. i think the kits have .091 seats and he said i could drill safely to .098 or so and still have them seal, you would need a small lathe to do it right. the old strip kit size was .110
Re: Thermoquad needle and seat [Re: ademon] #1150008
01/04/12 11:33 PM
01/04/12 11:33 PM
Gilbert, AZ
Gilbert, AZ
Thanks for the replies. I have a set of .110's but the end of the needles are not perfect and they will leak. I really need another set of .110's or larger. I'm waiting on replies from a couple of suppliers that may have some.
Raul
Re: Thermoquad needle and seat [Re: Aspen7695] #1150009
01/05/12 09:58 AM
01/05/12 09:58 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
To my knowledge, they are long gone and they are necessary for high HP applications.
I bought out what little stock one supplier had left years ago and have used most of them in carbs I have done for people.
If you already have used .110 seats, get needles from a new standard kit, the needles are usually big enough for a .110 seat (or even larger). Also, you may get away with lightly used standard needles if you have some that are in good shape because the contact circle will not be in the same place.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Thermoquad needle and seat [Re: Rapid340] #1150010
01/05/12 01:44 PM
01/05/12 01:44 PM
Gilbert, AZ
Gilbert, AZ
Rapid340 Thanks for the information. I was afraid to try using the smaller needles. I have some new ones so I'll put them in the .110 seats.
Raul
