Page 9 of 47 1 2 7 8 9 10 11 46 47
Re: 1969 Barracuda M code [Re: MLR426] #1149047
03/11/12 03:36 PM
03/11/12 03:36 PM
St.Louis, MO
694406 Offline
694406  Offline
St.Louis, MO
Guys whats the current range of value for a number 4 car on a 5 grading scale ? This would be a cuda coupe, complete running, numbers correct 440 engine, needing complete restoration, with a decent sound body but needing quarters ??
logan426
What color is it Martin?
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 Cuda 383 4-spd Notch
1969 GTS Black on White 340 4-spd
1971 Cuda 383 V2, X9 Billboards, White Top!
Re: 1969 Barracuda M code [Re: Rhinodart] #1149048
03/12/12 10:00 AM
03/12/12 10:00 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
In the $10K- 15K range right now. The rusty one in my pic above was bought for $10K 5 years ago. I really need to come over and check out your car!
This car isn't rotted like the one you pictured, it's in much better shape, if your blue one is a 5 then I possible down graded this one to far, it should be a 3 then. Possibly 15-20k then. But will these cars actually bring in that dollar ???
Jim, That would be (cars) not car
I have the 2 67's fastbacks I need to get on the market. an original owner damaged blue numbers match 383 4 spd as well as a maroon rolling body 273 4 spd.
Re: 1969 Barracuda M code [Re: MLR426] #1149049
03/12/12 10:26 AM
03/12/12 10:26 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I love this post...
Re: 1969 Barracuda M code [Re: Cuda340] #1149050
03/12/12 11:19 AM
03/12/12 11:19 AM
cali
68mannix Offline
68mannix  Offline
cali
please post pics of these m codes in the rough,thats what i like and others like to see ,as we all have seen restored ones.
Re: 1969 Barracuda M code [Re: 68mannix] #1149051
03/12/12 11:10 PM
03/12/12 11:10 PM
USA
big-block-dave Offline
USA
Yes, i also would like pics. Would you be willing to add it to the registry that i am taking car of?
Rite now there are 17 coupes that i have tag info on. There is a couple of weird things about the coupes that i have listed. WE, M-code 'cuda owners, like to see the different cars that still exist. All owners were given up dated info back in '02 by Tom. When i update further, owners will get a new information package with all current cars. I have in the past year added 3 new fastbacks. 1 has only 84xx miles on it!
68mannix, sounds like you have a M-code also? If 'cuda would love to add it to the registry also!! LMK
As stated on the bottom of my post, info isn't given out publicly.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 1969 Barracuda M code [Re: MLR426] #1149052
03/12/12 11:39 PM
03/12/12 11:39 PM
USA
USA
Logan426....want to trade your coupe for the white fastback i posted the picture of?????????
Re: 1969 Barracuda M code [Re: A12] #1149053
03/13/12 01:48 AM
03/13/12 01:48 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Well maybe..............
LS23M9B248***: GTS#8:"M" code 440 auto GTS owned by Mike from OH. It is in need of a full restoration. F8 Green w/ black interior and black vinyl top. It is a "stripe delete" GTS and was equipped with a 3.91 SureGrip.
Now how could you know this without a broadcast sheet? , stripe delete is on he fender tag the rear gear is not .
Re: 1969 Barracuda M code [Re: Troy] #1149054
03/13/12 01:58 AM
03/13/12 01:58 AM
JohnRR Offline
JohnRR  Offline
So would an M-code Cuda or Dart make a good F.A.S.T. car and has anyone competed with one yet?
I know stock tire size would be an issue but you could go one width size larger (F70-14 to G70-14) from what I'm told for a little help.
I know the intake/carb combo and the manafolds would be a killer for making any real power.
Mike I missed this ... it would run ok but the intake and single 4bbl basically make it a non competitive package. As long as you don't want to run near the top .. into the 9's , it would be a solid 11 sec ride.
Re: 1969 Barracuda M code [Re: JohnRR] #1149055
03/13/12 02:40 AM
03/13/12 02:40 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Well John you got me there but it still has the original diff and axle in it and the 3.91 tag on the diff....but I know that's still a guess....and there is no sign of the stripe on the tail of the original paint or the tag another guess, your right.
I'll need a ruling on this then, what do you guys think, did this M-code Dart GTS have a stripe or not....this is the original paint and it was a Southwest car and always garage kept since it was hauled back from there...a solid car and I can't find any signs of a tail stripe ever
Re: 1969 Barracuda M code [Re: A12] #1149056
03/13/12 02:42 AM
03/13/12 02:42 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
2
Re: 1969 Barracuda M code [Re: A12] #1149057
03/13/12 02:55 AM
03/13/12 02:55 AM
USA
USA
I'd say stripe delete, did you pull the side markers and check for stripe in the marker relief pocket?
That's going to be a nice one when you get her done!!!
Re: 1969 Barracuda M code [Re: JohnRR] #1149058
03/13/12 03:02 AM
03/13/12 03:02 AM
USA
USA
All M-code 'cudas(and Darts) came with E70-14s, cause they're ALL 'cuda package cars. As well as ALL Formula "S" and any 340 or 383 'cuda package cars! Even 318 cars if optioned for certain things. My 318 survivor MODTOP came factory with the 5.5" wheels/deep dish wheel covers/E70-14 Firestone white streak tires!!!
PS...My MODTOP will be in the MODTOP gathering in building Y at Carlisle this July.....LOOK ME UP AND BS M-CODES!!!!!!!!
Re: 1969 Barracuda M code [Re: big-block-dave] #1149059
03/13/12 03:19 AM
03/13/12 03:19 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks Dave, the markers and the drip rail were the first places I looked and so did the friend that I bought it from also looked and looked and...well you know. Yeah I can't wait to get started on it and running, it was the second car that I wanted back in '69, the first was a '69 383 GTS in F8, black interior no vinyl roof and then I read about the 440 M-code and couldn't find a dealer that knew anything about it or wanted to look or even try to order one. Got so disappointed that I ordered a road runner in F5, black, bucket seat, console interior (this one, that photo is back in the summer of '69), my parents were going to have to co-sign for the loan and mom didn't want to see me get a "compact" waited 30-years and found one by coincidence from a best friend I made through Mopars and dirt bikes, who'd a thunk it
Re: 1969 Barracuda M code [Re: A12] #1149060
03/13/12 03:35 AM
03/13/12 03:35 AM
USA
USA
Mike, that sounds like a GREAT friend! Very cool pic of the RR back then! Do ya still have the good looking fender ornament????
Re: 1969 Barracuda M code [Re: big-block-dave] #1149061
03/13/12 09:35 AM
03/13/12 09:35 AM
Winnipeg
O
OneOfMany Offline
OneOfMany  Offline
O
Winnipeg
Great looking project A12.. From limited looking at the pics, I'd guess stripe delete as well..
More pics is aways good!
Grant
Re: 1969 Barracuda M code [Re: OneOfMany] #1149062
03/13/12 10:39 AM
03/13/12 10:39 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The real way to tell if it is a stripe delete would be the GTS letters on the front fenders! All 69 stripe delete cars had these, if not, then it could have been a stripe that was removed at the dealer, seen it before! Mine came with GTSPORT stripe on one side and DART SWINGER on the other, maybe the dealer noticed it and removed it, the dealer mine came from didn't notice or didn't care.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Barracuda M code [Re: Rhinodart] #1149063
03/13/12 11:55 AM
03/13/12 11:55 AM
JohnRR Offline
JohnRR  Offline
Beat me too it .
Mike you know I had to throw that out there about the tag
On a side note I can't find those 69 GTS emblems anymore , are they still repopped ?
Re: 1969 Barracuda M code [Re: A12] #1149064
03/13/12 12:02 PM
03/13/12 12:02 PM
JohnRR Offline
JohnRR  Offline
I have that exact car and I'll trade ya it for that ratty old GTS ...
it's also stripe delete and 3.91 geared .
Re: 1969 Barracuda M code [Re: JohnRR] #1149065
03/13/12 12:41 PM
03/13/12 12:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Beat me too it .
I knew that was coming from you, I was waiting for your next reply before I posted about the callouts. You taught me to be thick skinned or go back on the porch and watch the real dogs play
And now I know why it HAS the GTS callouts on the front fenders.....don't have a photo here on this computer but I'll post it later this evening. Thanks guys
Hmmmmmmmmm a running, well tuned, 383 '69 Dart GTS in F8 green WITHOUT a vinyl roof for trade that going to cause some sleepless nights...thanks John
Re: 1969 Barracuda M code [Re: A12] #1149066
03/13/12 08:16 PM
03/13/12 08:16 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here we go again, flipper John....
A-Body's RULE!
