Page 1 of 3 1 2 3
0.060"... is still decent enough for quench ? #1146188
12/29/11 12:38 AM
12/29/11 12:38 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
what you read
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146189
12/29/11 12:44 AM
12/29/11 12:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats on the big side... .040-.045 would be better
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146190
12/29/11 12:46 AM
12/29/11 12:46 AM
unfortunately not close enough
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146191
12/29/11 01:00 AM
12/29/11 01:00 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
It is BETTER than a stock 906 head with a 39 gasket and an 80-down piston ...
Re: 0.060"... is still decent enough for quench ? [Re: RapidRobert] #1146192
12/29/11 01:02 AM
12/29/11 01:02 AM
Valencia, España
Valencia, España
well theeen won't be really posible a perfect quench at least in some pistons... The block was HORRIBLE BADLY DECKED. With around 0.012" diff between front and rear. It can't be fixed again since rears are now around 0 deck, maybe in fact couple of cents above.
add some cents more due the combustion chamber polish job, plus composite gasket, and I will be around 0.060 in front pistons and around 0.047 maybe ? in rears. I was to use metallic, but is not posible now with what I got in rear of the block, making mandatory to use composite
You can't imagine how much angry I am for this after lot of money and headaches, but is not posible to get an step back.
I made what I could, but when you have just idiots around with the machines, you can't make anything than pray to God ( I wasn't apparently heard )
Re: 0.060"... is still decent enough for quench ? [Re: dOc !] #1146193
12/29/11 01:04 AM
12/29/11 01:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Are you sure? Yeah it has more compression but it creates enough cylinder pressure that detonation becomes a serious concern but gets little if any benefit of quench.... I would cut the deck another .015-.020
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146194
12/29/11 01:08 AM
12/29/11 01:08 AM
Valencia, España
Valencia, España
( unless I grind a little bit the rear cilinders flat combustion chamber section and still use metallic gaskets? but that will increase the compression too, close to 10.8 maybe )
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146195
12/29/11 01:15 AM
12/29/11 01:15 AM
Sorry for your misfortune. would it be possible for you to plunge cut the chambers at each chamber end which'll have a side bennie of improveing flow and or can mill valve reliefs or mill the existing ones deeper. Maintain .150" deck thickness & you're good
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146196
12/29/11 01:15 AM
12/29/11 01:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
10.6 with good effective quench will be easier to live with than 10.0 without quench....
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146197
12/29/11 01:19 AM
12/29/11 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You got what you got... SO... run it.... is it the
best... NO... will it run... YES.... BUMMER about
your block and the LACK of machine work... quality...
you might be using different plugs in the front to
the rear... maybe jetting also to balance the cyl's
Re: 0.060"... is still decent enough for quench ? [Re: 1_WILD_RT] #1146198
12/29/11 01:38 AM
12/29/11 01:38 AM
Valencia, España
Valencia, España
sorry, recalculated and edited... maybe closer to 10.8
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146199
12/29/11 01:46 AM
12/29/11 01:46 AM
How good's the gas down there Nacho
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146200
12/29/11 01:51 AM
12/29/11 01:51 AM
Valencia, España
Valencia, España
I'm begining now my hunt for a new block, no matter conditions and even if need to sleeve, nice, since I have around same KB215s in standard size waiting for.
just the block and all the inners will be moved from one to the I HOPE SOON "new" block. Now I simply have to end to build and live with it.
I have some more "details" with this build. One of them: Some valves steems are at diff heights ( thanks God I got PRW adjustable rockers ), so that means the seats are deeper in some. Plus the angles are not right; machine shop made me 0-45- and I think 75 angle job. AND I TOLD THEM to make 30 on the chamber angle.
on the "good" side, the porting I made wasn't excesivelly bad even being my first job on this kind of stuff. After the big grinds I made, I sent the heads to a friend to make equal all the volumes. I got 208 +/-1 CCs on intake runners, 64 +/-1 CCs on exhaust runners and between 91 and 91.5 CCs on combustion chambers ( 452 heads )
Re: 0.060"... is still decent enough for quench ? [Re: RapidRobert] #1146201
12/29/11 01:55 AM
12/29/11 01:55 AM
Valencia, España
Valencia, España
we run at pumps 91 and 95 octanes, unleaded... quality ?... only God Knows.
I won't install metallic gaskets to make 10.8 on iron heads, no way. Even with great quality gas, it's dangerous. I already have seen KBs melted by preignition at ring grooves for excesive compression rate on iron heads. Rings allmost welded to the piston. I have these pistons in hands
This was part of another TERRIBLE bad machine job. Not mine Thanks God.
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146202
12/29/11 02:00 AM
12/29/11 02:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You need to find someone who can square deck the block. This is where the take more off one end of the deck than the others so that ALL pistons end up the same depth in the hole. So sounds like the front cylinders need some milling but the rears are good. For any decent machine shop, this should be easy.
Re: 0.060"... is still decent enough for quench ? [Re: DaytonaTurbo] #1146203
12/29/11 02:03 AM
12/29/11 02:03 AM
Valencia, España
Valencia, España
AH!! that was what I made before this result... I had the OPPOSITE slope. Fronts around 0.017 deck clearence and rears around 0.026 deck clearence, so around 0.008-9 difference. Sent to machine shop to correct this, and now I am WORST. No way, I'm not taking the risk, not at least at this moment
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146204
12/29/11 02:23 AM
12/29/11 02:23 AM
Manitoba, Canada
Manitoba, Canada
Even a different block will still need to be squared to get quench dead on. I still think you're going to need to find yourself a useful machine shop.
Re: 0.060"... is still decent enough for quench ? [Re: DaytonaTurbo] #1146205
12/29/11 10:22 AM
12/29/11 10:22 AM
Valencia, España
Valencia, España
defintelly! I agreed.
Re: 0.060"... is still decent enough for quench ? [Re: NachoRT74] #1146206
12/29/11 10:34 AM
12/29/11 10:34 AM
Nacho remember several years ago when I (strongly) suggested that you (re) locate up here. The women are foxy the beer is cold and the machine shops are conscientious (for the most part). Just think what you can buy with the shipping dollars that you'll save.
Re: 0.060"... is still decent enough for quench ? [Re: RapidRobert] #1146207
12/30/11 11:48 AM
12/30/11 11:48 AM
Valencia, España
Valencia, España
I'd like, but is not that easy to get a "green card" to live in USA being foreigner. I just have "easy" the tourist deal but that's just because my spanish origins gave mne the right to the European Passport ( I have Spanish nationality allong with the Venezuelan ). I don't need anykind of permission to enter in USA as tourist, just fill a from on line to report my visit, but that's it!
You have not Idea how many forms and requirements needs to get and give to the USA Embassy a regular Venezuelan to go to USA just as a tourist. And maybe just 70% or less get the aproovements.
Page 1 of 3 1 2 3
