Re: 0.060"... is still decent enough for quench ?
[Re: NachoRT74]
#1146208
12/30/11 12:36 PM
12/30/11 12:36 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
The solution is to have an American girl fall in love with you and marry you. Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: NachoRT74]
#1146209
01/02/12 06:53 PM
01/02/12 06:53 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I'd like, but is not that easy to get a "green card" to live in USA being foreigner. I just have "easy" the tourist deal but that's just because my spanish origins gave mne the right to the European Passport ( I have Spanish nationality allong with the Venezuelan ). I don't need anykind of permission to enter in USA as tourist, just fill a from on line to report my visit, but that's it!
You have not Idea how many forms and requirements needs to get and give to the USA Embassy a regular Venezuelan to go to USA just as a tourist. And maybe just 70% or less get the aproovements.
There are close to 30 million that didn't bother to get a green card , what's one more ???
[Re: JohnRR]
#1146210
01/03/12 03:48 AM
01/03/12 03:48 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
at least would be a Mopar guy without a green card LOL
[Re: joedust451]
#1146212
01/03/12 05:08 PM
01/03/12 05:08 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What cam are you using....that will play a major role on compression, detonation, or lack there of.
Im not in agreement with the comment about quench and detonation..
Ive run 1. 10.5 with 452s, shim gaskets,KB step pistons and a .509. Never a hint of detonation. QQuench in the .065 range. Varied due to the chambers on the pistons, but .065 average.
2. 10.5 with the same heads, ROL .045 gaskets, Probe flat tops. No quench. 259/259 Comp Solid. It would get very light pinging on a very hot humid OK day with 91 with 36 degrees of timing. Back the timing to 34 and no issues.
3. 9.8 with 346s and same KB step pistons. .045 Detroit gaskets. Small Comp solid. Runs fine on 89...with around .065 quench. Might run on 87. Im gonna find out. LOL.
Numerous SBC dirt motors that "according to popular belief" wouldnt run on pump 91 swill...without breaking stuff. A couple of SBC street motors that were over 10 to 1 and ran fine oon 91. I did break 2 pistons in a fresh 383 SBC that was over 11 to 1. Cast pistons, 6500 RPM and pump 91 didnt do the pistons very good.....Never had any problems on a short track. Went to a big track and killed it in 12 laps...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: JohnRR]
#1146214
01/03/12 07:13 PM
01/03/12 07:13 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
A good machinest can streighten up that deck for you.
His problem is a good machinist is 3000 miles away ...
That sucks
[Re: 360view]
#1146219
01/04/12 09:54 AM
01/04/12 09:54 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: NachoRT74]
#1146220
01/04/12 09:40 PM
01/04/12 09:40 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
That sucks
any "streighten" deck job will mean some more milling, maybe just couple cents, on the lower side but still will sit pistons more above the deck. 7 and 8 pistons are already around 0.005" above the deck.
You could simply straighten it out and put a thicker gasket on it. A little late now apparently.
Glad to here that you got it running....I seems like it's been a long road for you
[Re: BSB67]
#1146221
01/05/12 12:57 AM
01/05/12 12:57 AM
NachoRT74
Valencia, España
YES, A LONG RUN!!! Sorry, I never recorded the start up. I was alone and is not posible try to "tune up" everything to the first start up and record with the phone at the time I hope you like ( still have to set the initial timming and tune up everything ( mixture and correct iddle ) it was at around 900 RPMs as far I remember https://www.facebook.com/photo.php?v=10150496075198753If you have FB will be able to enter. Is posted on an open group
[Re: JohnRR]
#1146223
01/05/12 02:17 PM
01/05/12 02:17 PM
NachoRT74
Valencia, España
yeap! I couldn't hold the engine assembly more. This took too much to be done and the mechanic shop need the place done because my mechanic is leaving that shop
[Re: NachoRT74]
#1146224
01/05/12 04:08 PM
01/05/12 04:08 PM
JohnRR
Then there was really no need to ask the question because you couldn't/weren't going to do anything about it , it's a moot point .
[Re: crlush]
#1146227
01/06/12 11:08 AM
01/06/12 11:08 AM
JohnRR
Find someone to deck the block right.
The engine is together and running, that's not going to happen , all he can do is hope for the best and adjust his tune accordingly.
Don't get crazy on the timing advance.
