B body wiper bushings - info only #1145027
12/27/11 01:42 PM
12/27/11 01:42 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
I get asked about these from time to time and thought pictures might better explain it.
The 1968 to 1970 B-body wiper pivots use these square plastic snap in bushings ( I also believe the same era A-bodies use tham as well )
Here goes.
The bushings themselves
Re: B body wiper bushings - info only [Re: gtx6970] #1145028
12/27/11 01:44 PM
12/27/11 01:44 PM
It's a dry heat
It's a dry heat
And the crank arm end bushing
3 speed on the right
2 speed on the left
Re: B body wiper bushings - info only [Re: gtx6970] #1145029
12/27/11 01:46 PM
12/27/11 01:46 PM
It's a dry heat
It's a dry heat
The drivers side end. This one has 2 pins and link connections.
The bushings snap into the link arm and then the pin snaps into the bushings.
Top link goes to the wiper motor crank arm
Bottom link goes to the pass side wiper pivot.
Re: B body wiper bushings - info only [Re: gtx6970] #1145030
12/27/11 01:48 PM
12/27/11 01:48 PM
It's a dry heat
It's a dry heat
Pass side , It just has the one bushing that comes from the drivers side pivot.
Re: B body wiper bushings - info only [Re: gtx6970] #1145031
12/27/11 01:50 PM
12/27/11 01:50 PM
It's a dry heat
It's a dry heat
The crank arm end - 3 speed version
In an exploded view to see how it all goes together.
Re: B body wiper bushings - info only [Re: gtx6970] #1145032
12/27/11 01:51 PM
12/27/11 01:51 PM
It's a dry heat
It's a dry heat
Same components, assembled and lubed.
Re: B body wiper bushings - info only [Re: gtx6970] #1145033
12/27/11 03:11 PM
12/27/11 03:11 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill GREAT POST AND INFO
MikeR
Re: B body wiper bushings - info only [Re: A12] #1145034
12/27/11 03:55 PM
12/27/11 03:55 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Bill,
I did my 68 road runner wiper stuff a few years ago but my 3 speed bushings etc. on the crank arm were a bit different. I found an NOS "kit" on the net and it matched up perfectly with what I had. Have you come across this before? I think the full part # is 2809040.
Re: B body wiper bushings - info only [Re: 68jim] #1145035
12/27/11 03:56 PM
12/27/11 03:56 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
It is currently installed on the car and works just fine.
Re: B body wiper bushings - info only [Re: 68jim] #1145036
12/27/11 04:02 PM
12/27/11 04:02 PM
It's a dry heat
It's a dry heat
Bill,
Jim,
sorry, I can't answer that one.
I'm not familiar with the 68's very well. And the '68 Charger I have in the shop is a 2 speed wiper car, so it's no help.
The pics I posted are from a '69 Charger with 3 speed wipers and every piece was indentical to what came off the car.
Jules if your reading this, your more than welcome to chime in
Re: B body wiper bushings - info only [Re: gtx6970] #1145037
12/27/11 07:43 PM
12/27/11 07:43 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
68 only and the crank arm is different also.
69-70 is a 273 part number.
68 is a V speed crank arm.
Jules
Re: B body wiper bushings - info only [Re: JulesdaWiperman] #1145038
01/09/12 04:19 PM
01/09/12 04:19 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Can this setup be used on late B body's with the troublesome bushing setup they have?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: B body wiper bushings - info only [Re: Magnumguy] #1145039
01/09/12 08:41 PM
01/09/12 08:41 PM
super gas
super gas
Nope. Incorrect geometry.
Shaft size and possibly other reasons.
Jules
