antenna 2008 Avenger
#1143240
12/24/11 01:58 PM
12/24/11 01:58 PM
Posts: 27,728 places
79powerwagon
places
My radio reception is poor in my 08 Avenger, and of course, the first line of defense is a replacement part. I bought a Mopar rubber whip (like original, on the roof mounted Sirius/AM/FM roof-mounted unit), and naturally, the old one just spins on the base and does not come loose or unscrew. Can I try some more "aggressive" means to get the whip off, or does this mean replacing the base as well? And if so, am I lucky enough that the whole base is done from the OUTSIDE, rather than removing the headliner, etc?
Re: antenna 2008 Avenger
[Re: 79powerwagon]
#1143241
12/24/11 04:31 PM
12/24/11 04:31 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Poor reception? Is it the factory radio or an aftermarket radio?
Just asking because my Neon had great reception until I replaced the radio. Now I seem to loose reception in places my cars with factory radios don't.
No longer taking $h!t from anyone!
[Re: DUFFMAN]
#1143242
12/24/11 04:43 PM
12/24/11 04:43 PM
79powerwagon
places
Stock AM/FM/CD/MP3 (single disc)/Sirius/iPod... Sorry, model RES...
[Re: DirectSubjection]
#1143245
12/26/11 09:06 AM
12/26/11 09:06 AM
79powerwagon
places
That occurred to me...
As long as a couple of the buttons on my radio are broken, I just won a replacement on the bay to install, to rule out the head unit.
Digging around on the web, I still haven't found much regarding the antenna base and how it's installed. I suppose it's safe to assume it is NOT an easy replacement, if needed.
[Re: 79powerwagon]
#1143248
12/30/11 05:38 PM
12/30/11 05:38 PM
79powerwagon
places
Got my replacement head unit today ($19.95 off the 'bay! ) and I wasn't aware at how many features didn't work on the old one! Stations are better, but still not up to snuff, especially for a 3 year old car. Pretty easy to install the head unit! I bet it took four whole minutes to swap them out! So, I'm back to my antenna question. Can this AM/FM/Sirius antenna be replaced from the outside, or must I drop the headliner?
[Re: 79powerwagon]
#1143251
12/30/11 08:11 PM
12/30/11 08:11 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
I just googled "antenna replacement on 2008 dodge avenger". One of the links was inhabited by Dodge techs (21 were online at the time). Sorry I should have copied and pasted the link. It's probably easier than Volvo electrical work... EDIT I PM'd the link - let me know if it helps!
Old, tired, and sometimes broke down. Me, not my car...
[Re: Shoozy]
#1143252
01/01/12 06:10 PM
01/01/12 06:10 PM
79powerwagon
places
Is the satellite antenna separate from the antenna base? I saw two different bases in photographs, but http://www.makeitdodgeparts.com/accessories.htm only shows one base. My goal is to get the AM/FM working like it should, but I want to retain the Sirius as well...
[Re: 79powerwagon]
#1143253
01/01/12 06:25 PM
01/01/12 06:25 PM
Shoozy
Southern by Choice
um you have the car, I don't That site I sent allows questions, etc. If I told you something it would probably be wrong anyway. If you're not in a big hurry I could come over and take a look. Sorry I don't have a late model Mopar to compare it to. Did you drop the headliner yet?
