how much room needed around a rear tire #1142169
12/22/11 11:56 PM
12/22/11 11:56 PM
mo
ALKYW5DART Offline OP
mo
just bought new tires and put them on a 12' rim damn there huge but how much space is needed on either side of tire so it dosen't rub. I have right at 1/2 inch inbetween frame and 1/2 on wheel well side is that enuff
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142170
12/22/11 11:58 PM
12/22/11 11:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
Depends on the tire (Bias or Radial), and application (Drag only or Street/Strip), but I would generally be happy with 1/2 an inch.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142171
12/23/11 12:01 AM
12/23/11 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats on the close side... I like to see about 3/4
minimum... but thats me
Re: how much room needed around a rear tire [Re: Triple Threat] #1142172
12/23/11 12:02 AM
12/23/11 12:02 AM
mo
mo
ok sorry its a 30x11x15 bias ply slick and its a drag car only 10 miles a year on street, also how much room needed in front for growth
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142173
12/23/11 12:05 AM
12/23/11 12:05 AM
Renton Washington
Renton Washington
How fast is it?
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142174
12/23/11 12:19 AM
12/23/11 12:19 AM
gregsdart Offline
gregsdart  Offline
I have run tighter, like 7/16 inside/outside but both sides of the slicks are showing rub marks. I lube the tires with tire shine real well to help. The rubbing comes when going around corners on the return roads, etc. At speed the sidewalls are pulled in and have more room. As for the face of the slick, one inch should be enough. I would look for anything that could leave a gouge in the tire surface if it did make contact though, and smooth that out so it won't tear up the slick.
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142175
12/23/11 12:22 AM
12/23/11 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I like 3/4 everywhere... I have touched at 1/2
mainly in the front... so 3/4 works for me...
if you think its gonna touch put a radius there
so it rubs on a radius instead of something sharp
Re: how much room needed around a rear tire [Re: Triple Threat] #1142176
12/23/11 12:36 AM
12/23/11 12:36 AM
mo
mo
How fast is it?
9.50's to 9.70's in quarter
Re: how much room needed around a rear tire [Re: MR_P_BODY] #1142177
12/23/11 12:39 AM
12/23/11 12:39 AM
mo
mo
should i go with the 10" wide wheels so its not so wide, but i was trying to go with a wider wheel to flatten tread out
Re: how much room needed around a rear tire [Re: ALKYW5DART] #1142178
12/23/11 01:06 AM
12/23/11 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not so much about the sides... just make sure
you dont have any sharp edges... the turns will get
the sides if your driving too quick... I got loose
one time and put a nick in my side wall... so I rolled
the lips and got 3/4... never had any issues since
Re: how much room needed around a rear tire [Re: MR_P_BODY] #1142179
12/23/11 05:09 PM
12/23/11 05:09 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I have exactly 1/2 inch of clearence between the slick sidewalls and the leaf springs on my 64 Dart on both sides.My pinky wont fit in between them.Its been this way for the last 3 seasons and hasnt rubbed yet ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: how much room needed around a rear tire [Re: The Shocker] #1142180
12/23/11 05:51 PM
12/23/11 05:51 PM
NV
my88 Offline
my88  Offline
NV
if it's a drag car 3/4" should be good. the section width is or sidewall and how soft it is is whats important. If you put a 10" wheel vs a 12" then you section width is going to buldge more. measure from the front face of your drum to the lip on your outer wheel well if your putting a 12" wheel on with 6" of back spacing and you have 7.5" from drum to inner wheel lip you add 1" for section width making 7" gives you 1/2" you can also measure from the inner whell well to outer to find out how much tire you can stuff in there. The closer the tire to the lip the less body roll you can have, which makes street drive no fun
2003 ram 2500 05 CTS 1967 chevelle
