Spark Plugs For A Warmed Up 318? #1141709
12/22/11 12:04 PM
12/22/11 12:04 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Hoping to fire the fresh built 318 this weekend:
'86 roller block +.020"
kb 167's .010" in the hole
J heads milled .030"
Eddy Performer
Eddy 600 cfm
Reground factory roller, 210@.050, .428"
Stock manifolds
Spark plug recommendations?
Re: Spark Plugs For A Warmed Up 318? [Re: vdriver] #1141710
12/22/11 12:27 PM
12/22/11 12:27 PM
scratchnfotraction Offline
autolight 65 is what it calls for.
I mostly run this plug on all my SB engines.
for name brand,what ever cross over is listed.
good luck on the fire-up
Re: Spark Plugs For A Warmed Up 318? [Re: scratchnfotraction] #1141711
12/22/11 12:35 PM
12/22/11 12:35 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
X2
Re: Spark Plugs For A Warmed Up 318? [Re: 65rbdodge] #1141712
12/22/11 12:59 PM
12/22/11 12:59 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Same here.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Spark Plugs For A Warmed Up 318? [Re: vdriver] #1141713
12/22/11 01:22 PM
12/22/11 01:22 PM
I have Autolite 85's in my DD 318. Made in China now I understand. Any stock heat range will work for you. OT might read "breakin secrets" at www.mototuneusa.com (5 minute read) (30 minutes if you read at DogDays' comprehension level) EDIT the #1406 is lean, might go up 1 jet size (from 95 to 98 iirc) MORE EDIT I may be thinking 65's (& I just pulled one yesterday)
Re: Spark Plugs For A Warmed Up 318? [Re: RapidRobert] #1141714
12/23/11 12:59 PM
12/23/11 12:59 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
NGK V power that cross over.
Autolite is Chinese.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
