Dampeners #1140091
12/20/11 11:22 AM
12/20/11 11:22 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
What is everybody running for dampeners on their centrifugal style blower motors? One or two keyways? Thanks, John
Fastest 300
Re: Dampeners [Re: Crizila] #1140092
12/20/11 01:17 PM
12/20/11 01:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what is a dampener?
Re: Dampeners [Re: Quicktree] #1140093
12/20/11 02:49 PM
12/20/11 02:49 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
that would be my wash clothe, when its wet. On a damper thou, I run the ATI Damper.
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Dampeners [Re: Quicktree] #1140094
12/20/11 05:21 PM
12/20/11 05:21 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
what is a dampener?
Sorry, it's one of those things that bolts to the front of the crank. Oh well, I guess I'm all wet - and don't spell to very good.
Fastest 300
Re: Dampeners [Re: Crizila] #1140095
12/20/11 07:22 PM
12/20/11 07:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what is a dampener?
don't feel bad neither do I
Re: Dampeners [Re: Quicktree] #1140096
12/20/11 07:30 PM
12/20/11 07:30 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
what is a dampener?
Oh YEAH ...
Follow my buidls at moparjunk@twitter.com
buidls ? ....is that a Chebby term ? ..
Re: Dampeners [Re: dOrk !] #1140097
12/20/11 08:40 PM
12/20/11 08:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what is a dampener?
Oh YEAH ...
no thats a typo, learn the difference
Re: Dampeners [Re: Quicktree] #1140098
12/20/11 08:48 PM
12/20/11 08:48 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
IS that like being too-quick on-the-tree and going RED by 0005 ?
Re: Dampeners [Re: dOrk !] #1140099
12/20/11 08:57 PM
12/20/11 08:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats from not having my glasses on I guess
Re: Dampeners [Re: Quicktree] #1140100
12/20/11 09:05 PM
12/20/11 09:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use a double keyway ATI superdamper.One of the best out there.Your better off with 2,limited boost with a single keyway.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dampeners [Re: hemi-itis] #1140101
12/20/11 11:42 PM
12/20/11 11:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run 12 PSI with a 6V-71 for 27 years. Stock 340 crank,stock key way,solid hub(no damper). Its no world beater but runs 11.00@3875lbs.Street use and hundreds of 1/4 passes shifting at 7000rpm.I replaced the bearings 5 years ago, the old ones looked perfect.
Doug
Re: Dampeners [Re: hemi-itis] #1140102
12/21/11 11:21 AM
12/21/11 11:21 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks. That's probably what I will go with.
Fastest 300
Re: Dampeners [Re: Crizila] #1140103
12/21/11 11:25 AM
12/21/11 11:25 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how limited on boost?
I see one that's run 12 psi on a single keyway.
I'm in the assembly stage of a friends motor, that he plans to feed 12-14 psi. it's an all forged magnum 5.9 Magnum
**Photobucket sucks**
Re: Dampeners [Re: 70Cuda383] #1140104
12/21/11 11:35 AM
12/21/11 11:35 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
My build will unclude running upwords of 20 PSI with a centrigugal style blower. Most are recommending 2 keys. Not sure which damper though.
Fastest 300
Re: Dampeners [Re: Crizila] #1140105
12/21/11 06:36 PM
12/21/11 06:36 PM
I like and use ATI
