Page 2 of 3 1 2 3
Re: Poor quality reproduction battery and poor customer svc [Re: MattMPA] #1139504
12/21/11 11:53 AM
12/21/11 11:53 AM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
I wonder if it can be repaired/rebuilt? That might help salvage money spent.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Poor quality reproduction battery and poor customer svc [Re: Dixie] #1139505
12/21/11 12:50 PM
12/21/11 12:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This would be better money spent if there is any chance of saving your battery:
http://www.optimate3.com/classic/
As simple as 1-2-3 : Just connect the OptiMate to your battery and the 6 stage program does the rest automatically and safely
Diagnoses & desulfates batteries safely
Suitable for all types of 12V lead-acid batteries
Maintains your battery automatically for months
Checks for & indicates unusual self-discharge trends
Recommended by major power sports vehicle OEMs
Full electronic & passive protection
OptiMate's unique algorithm (graph) specifically designed for power sport starter batteries
International certification : UL & CSA (USA & Canada), PSE (Japan), TüV/GS & CE (Europe), SAA (Australia)
2-year warranty and personal after sales service
MikeR
Re: Poor quality reproduction battery and poor customer svc [Re: Dixie] #1139506
12/22/11 02:42 AM
12/22/11 02:42 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I really liked the idea of gutting the (Now dead anyway...) repo battery and hiding a smaller, lighter, modern battery inside. You'd still look correct and that expensive case would be good forever.
Re: Poor quality reproduction battery and poor customer svc [Re: Silverbullet2] #1139507
12/22/11 09:37 AM
12/22/11 09:37 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A stock looking battery cover sounds like a potential new product.
Re: Poor quality reproduction battery and poor customer svc [Re: DoctorDiff] #1139508
12/22/11 10:47 AM
12/22/11 10:47 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
They already have them for years now if you mean a "battery topper".........
Re: Poor quality reproduction battery and poor customer svc [Re: A12] #1139509
12/22/11 12:19 PM
12/22/11 12:19 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
which dont fit well and dont look stock.
Re: Poor quality reproduction battery and poor customer svc [Re: 05dakota] #1139510
12/22/11 12:31 PM
12/22/11 12:31 PM
Arizona
az426john Offline
az426john  Offline
Arizona
And the Red Tops only come in size 24 which is not correct.
It might be OK in some applications where only the top of the battery can be seen like some Corvettes but Mopars are generally easily seen.
Re: Poor quality reproduction battery and poor customer svc [Re: az426john] #1139511
12/22/11 01:25 PM
12/22/11 01:25 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Seems the original batteries that come with oem cars always outlast anything out there...My 2000 ford diesel van has two batteies, I just changed the original motorcrafts last year... The new batteries are already having trouble turning the engine on cold days... they're loosing cranking amps and decaying at a much quicker rate.
You can bet the dealers don't want batteries giving up under the warrantee of a new car... I'm positive original oem batteries are "different" than anything you can buy over a parts counter.
For the record, the reproduction antique batteries never seem to last more than a few years no matter how much use they get...or how well they are maintained.
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: Poor quality reproduction battery and poor customer svc [Re: DoctorDiff] #1139512
12/22/11 06:21 PM
12/22/11 06:21 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
, stock and correct looking... another job for Dave Walden or Mike Ross...
Re: Poor quality reproduction battery and poor customer svc [Re: rayztoy] #1139513
12/22/11 06:39 PM
12/22/11 06:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Along with a battery hold down that is a little wider that looks OE and fits.....the covers are wider to fit over a group 24 battery so the stock hold down doesn't fit without modifications. And they need to be made for a correct Group 27 size battery not the Group 24
Re: Poor quality reproduction battery and poor customer svc [Re: rayztoy] #1139514
12/22/11 06:47 PM
12/22/11 06:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if a correct battery appearance is only important when you are showing the car, drain the acid out of the dead one, rinse it thoughly with distilled water and only put it in at shows. PITA i know but a battery will only last so long before it's eaten itself alive. then it will attack the case and unnoticed you will have a bigger problem on your hands - don't ask how i know! and thanks again for the GREAT customer service! i recommend you every chance i get!
Re: Poor quality reproduction battery and poor customer svc [Re: 62maxwgn] #1139515
12/22/11 07:15 PM
12/22/11 07:15 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Two batteries in my Superbird in 19yrs,both from the original New Castle Battery Co,group 27,first was wet cell lasted almost nine years...
Same here...I've had exceptional service from mine,though I think it's getting weaker now. But I sure can't complain about the service from this battery.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Poor quality reproduction battery and poor customer svc [Re: 1_WILD_RT] #1139516
12/23/11 01:31 AM
12/23/11 01:31 AM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
After dealing with three failed reproduction batteries having the first one last eight months & get replaced under warranty but I got hit for shipping both ways , the second lasted about a year & they prorated it & I had to pay shipping both ways... The third battery failed & I did this....
This is what I did with mine also.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
Re: Poor quality reproduction battery and poor customer svc [Re: RareTA] #1139517
12/23/11 11:38 AM
12/23/11 11:38 AM
O
OLD318 Offline
OLD318  Offline
O
I hear you...my story is exactly the same...
I bought it...4 years to the day it was dead and
I only had about 2K on my car (70 Coronet 2 door hard top)
Along the way, I had to constantly re-charge it
(from the car sitting to long and not driving it)...
The guy basically said... those old style acid
batteries only last 48 months under those circumstances...
True, I could have used one of those trickle charge devices etc...
It seems like for the money it should have lasted alot longer...
I loved the appearance but I got sick and tired of the poor performance.
Now I'm running an interstate... (it cost 1/3 of the AAB)
I hate the look...but I'm not forking over that much coin
for another one...
Seems like an awful lot of "reproduction" stuff in this hobby
works out like this:
It looks nice, promises a lot... delivers very little,
and costs a fortune...
Oh well... guess we signed up for it
Re: Poor quality reproduction battery and poor customer svc [Re: OLD318] #1139518
12/24/11 08:28 AM
12/24/11 08:28 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
What a load of crap.
My '98 truck has the original Mopar battery in it with 149,000 miles (an exception to the rule to be sure) and gets driven once a month for dump runs. It might see less miles per year than your car!
I used to have a beater Spirit R/T that had an Interstate battery that was in *four cars* over a 12 year span of time before the CCA started dropping off.
My neon still has the OEM Mopar battery in it and it's an 2001 model with well over 100,000 miles.
All were parked outside in New England, year round.
Re: Poor quality reproduction battery and poor customer svc [Re: gdonovan] #1139519
12/24/11 12:38 PM
12/24/11 12:38 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Batteries seem to last longer when the vehicle is started periodically. I had problems when my cars sat 6-8 months, regardless of brand.
Re: Poor quality reproduction battery and poor customer svc [Re: DoctorDiff] #1139520
12/24/11 02:13 PM
12/24/11 02:13 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Batteries are one of those items that last longer the more they are used. They liked to be charged and cycled every day. The longer they sit, the shorter their life will be. That is why cars that aren't used everyday end up going through batteries faster. A car battery lasting 100,000 miles on the battery is more common than a car battery lasting 2,000 miles on the same battery. This has always been a problem on collector cars. A battery tended charger is a must. Just starting your car and letting it run once a month won't help. It takes many miles after you start your car to replenish the charge lost from starting the car, and even more miles to get the battery fully charged (like driving it all day). You'll spend more money on gas than you would for the price of a battery tender.
I volunteer at a very large car museum and all the batteries on the running cars are always rotated and charged on a regular basis. Batteries are being charged every day and when you get them all charged, you start over with the first one. We have several chargers going non-stop 24-7. It is a never ending process.
Lead acid batteries thrive from being cycled and they thrive from being topped off.
Same goes for batteries in everything else you use, like cordless tools. I have tools I use and charge every other day and those batteries last longer than the tools I use once every couple months.
Re: Poor quality reproduction battery and poor customer svc [Re: Steve340] #1139521
12/24/11 03:09 PM
12/24/11 03:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
While I agree batteries do typically last longer when used every day the first two batteries I had fail in my Challenger when the car was a fresh resto I was driving the car practically every day.. I lost them both in the first eighteen months.. I put about 25K miles on the car in that time.. It wasn't a garage queen... Those batteries were junk... The new sealed batteries probably are allot better but I will never know cause my Odyssey keeps on cranking it out...
Re: Poor quality reproduction battery and poor customer svc [Re: Steve340] #1139522
12/24/11 03:31 PM
12/24/11 03:31 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
That's why if mine lasts 4-5 years, I don't complain. I put less than 100 miles on my car since I put the maintenance free AAB yellow cap, group 24 in my car in 2007. It is my first non-lead acid battery and only my third repro battery (all from AAB) since 1989). I do not keep a battery tender on it but do periodically put the tender on it when my battery gets below about a 12.6 volts. I will put the tender on for a day or so and then forget about it the battery a couple of months. I warmed up the A12 and drove the car around the block on 12/3. Previously took it to a car show in mid September. The last time I started it before that was mid-June (trailered it to the Mopar Action show at Maple Grove). I just put the tender on it and it is holding 13.1 volts after only 10 minutes. I will definitely buy another Antique Auto battery when this one quits working.
Re: Poor quality reproduction battery and poor customer svc [Re: Steve340] #1139523
12/24/11 07:36 PM
12/24/11 07:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Obviously, starting a car then immediately shutting it off will discharge the battery.
My point is, an unattended battery usually lasts longer in a car that gets driven 1 day a month, than a car that gets driven a few consecutive days every 8 months.
Page 2 of 3 1 2 3
