? for the Stick guys only.. #1137791
12/17/11 06:04 PM
12/17/11 06:04 PM
Connecticut
5126brl No more Offline OP
Connecticut
I am trying to see what rpm you are going thru the traps at and with what Gears and tire size.
I am trying to get some more rpm at the top end and do not want to swap out my 4.10's
right now I'm at 5400 with 29" street tires. And when i compare to my friends with autos I see alot of convertor slip.
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137792
12/17/11 06:42 PM
12/17/11 06:42 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
bout 6200, i know the shift light comes on (6100) but either I don't remember or don't see it. Just getting old I guess.
28 x 9 tires
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: ? for the Stick guys only.. [Re: oldiron] #1137793
12/17/11 06:48 PM
12/17/11 06:48 PM
Connecticut
Connecticut
What gear in rear?
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137794
12/17/11 06:52 PM
12/17/11 06:52 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
oops - 4.10
Re: ? for the Stick guys only.. [Re: oldiron] #1137795
12/17/11 06:54 PM
12/17/11 06:54 PM
Connecticut
Connecticut
I remember your car White correct?
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137796
12/17/11 06:54 PM
12/17/11 06:54 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
I run a hoosier 29x9 slick Dana 4.10 gear 4-speed. Go threw at 6300 at 130 mph.
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137797
12/17/11 06:56 PM
12/17/11 06:56 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
black top w/white bottom
Re: ? for the Stick guys only.. [Re: rollerfork] #1137798
12/17/11 06:59 PM
12/17/11 06:59 PM
Connecticut
Connecticut
Great looking car... Love the slicks With Armoral
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137799
12/17/11 07:18 PM
12/17/11 07:18 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
Thanks, went a little overboard on tire shine
Re: ? for the Stick guys only.. [Re: rollerfork] #1137800
12/17/11 08:02 PM
12/17/11 08:02 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i was going through about 7,000 @ 130, at the same track its about 1 mph slower with an automatic 4.56 gear 29in tire. if it were a wedge i wouldn't be twisting it quite as hard.
http://youtu.be/HSUrUBZogDs
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: ? for the Stick guys only.. [Re: 68 HEMI GTS] #1137801
12/17/11 10:40 PM
12/17/11 10:40 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
At 130 mph ,I never look at the tach. The shift light does come on just past the finish line [ 6800 ] with 4.56 and 30" tire
Re: ? for the Stick guys only.. [Re: rowin4] #1137802
12/17/11 10:58 PM
12/17/11 10:58 PM
ohio
Rich970 Offline
Rich970  Offline
ohio
4.56 32" tire replay tach says 6900 7000.
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137803
12/17/11 11:33 PM
12/17/11 11:33 PM
WA
JD Dart Offline
JD Dart  Offline
WA
7225 rpm 154.99 mph 33" tall tires 4.33 gears
Re: ? for the Stick guys only.. [Re: JD Dart] #1137804
12/18/11 07:53 AM
12/18/11 07:53 AM
Netherlands
72Challenger Offline
Netherlands
4.56 gears w/ 33" tires crossing the line at about 6700-6800 running 8.9's.
Switching to 4.88 gears next season.
Re: ? for the Stick guys only.. [Re: 72Challenger] #1137805
12/18/11 10:43 AM
12/18/11 10:43 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
27x 10.50 et streets with a 4.10 crossing at 6400 with 126 mph
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137806
12/18/11 10:56 AM
12/18/11 10:56 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Shift lite comes on just before the finish line, so trap rpm is around 6300 rpm with 29" tall slicks and 4.56 gears @ around 119 mph.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: ? for the Stick guys only.. [Re: 68LAR] #1137807
12/18/11 12:27 PM
12/18/11 12:27 PM
Toronto
mshred Offline
mshred  Offline
Toronto
with 4.10's and 28" tall ET streets im crossing the traps at about 5500rpms....my shift lite is set for 6k, so ideally i need more gear to really optimize the combo
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137808
12/18/11 02:22 PM
12/18/11 02:22 PM
ohio
Rich970 Offline
Rich970  Offline
ohio
Can i ask what rpm you leave and shift at, what trans , ?
Re: ? for the Stick guys only.. [Re: 5126brl No more] #1137809
12/18/11 02:40 PM
12/18/11 02:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With my Richmond 5-speed I trap in fourth gear(1.24)fifth gear is direct 1 to 1.
I run 3.54 gears,28" slick,6600 RPM,125.6 MPH
Now when I was running a 4-gear I ran 4.56 gears and would trap at just over 6300 with 28"slicks.
Gus
64 Plymouth Savoy
Dana 60
Re: ? for the Stick guys only.. [Re: Rich970] #1137810
12/18/11 03:17 PM
12/18/11 03:17 PM
Connecticut
Connecticut
On that day I was running M/T street pros and was leaving at 3000 rpm . Was a fine line to walk to get them to hook. Any higher and they spun. 29x15.50 Street pros. I am looking into a set of Slicks 26x12.5 to try and get the rpm up and get into second before the 60 ft lights.
Trans is a Hemi box that has pro shifted 2nd, faceplated 3-4 and a Ram adjustable clutch with a organic disc. Set at 2700# now any lower and it just powers thru the clutch.
At 3800 lbs and 590 hp I think I should get down to 11.20's at 122 or so. Old setup would 11.0's at 123 mph with 13x31 and 5.13's and 3400 lbs.
